Ich möchte ein Programm schreiben mit dem man PDF-Dateien, die in einem Verzeichnis liegen, "durchklicken" kann (Quellcode unten). "Durchklicken" heißt, dass bestimmte Informationen zu der Datei angezeigt werden (zum Testen erstmal nur der Pfad).
Doch leider kommt es beim Compilieren zu den folgenden Fehlern:
papermanager.cpp: In constructor 'PaperManager::PaperManager()':
papermanager.cpp:23: error: no matching function for call to 'QGridLayout::addWidget(Paper&, int, int, int, int)'
/usr/include/qt4/QtGui/qgridlayout.h:112: note: candidates are: void QGridLayout::addWidget(QWidget*)
/usr/include/qt4/QtGui/qgridlayout.h:113: note: void QGridLayout::addWidget(QWidget*, int, int, Qt::Alignment)
/usr/include/qt4/QtGui/qgridlayout.h:114: note: void QGridLayout::addWidget(QWidget*, int, int, int, int, Qt::Alignment)
papermanager.cpp: In member function 'void PaperManager::readDirectory()':
papermanager.cpp:40: error: no matching function for call to 'QList<Paper>::append(Paper*)'
/usr/include/qt4/QtCore/qlist.h:414: note: candidates are: void QList<T>::append(const T&) [with T = Paper]
/usr/include/qt4/QtGui/qwidget.h: In copy constructor 'Paper::Paper(const Paper&)':
paper.h:8: instantiated from 'void QList<T>::node_copy(QList<T>::Node*, QList<T>::Node*, QList<T>::Node*) [with T = Paper]'
/usr/include/qt4/QtCore/qlist.h:517: instantiated from 'void QList<T>::detach_helper() [with T = Paper]'
/usr/include/qt4/QtCore/qlist.h:115: instantiated from 'void QList<T>::detach() [with T = Paper]'
/usr/include/qt4/QtCore/qlist.h:396: instantiated from 'T& QList<T>::operator[](int) [with T = Paper]'
papermanager.cpp:23: instantiated from here
/usr/include/qt4/QtGui/qwidget.h:746: error: 'QWidget::QWidget(const QWidget&)' is private
paper.h:8: error: within this context
/usr/include/qt4/QtCore/qlist.h: In member function 'void QList<T>::node_copy(QList<T>::Node*, QList<T>::Node*, QList<T>::Node*) [with T = Paper]':
/usr/include/qt4/QtCore/qlist.h:349: note: synthesized method 'Paper::Paper(const Paper&)' first required here
papermanager.h
#ifndef PAPERMANAGER_H
#define PAPERMANAGER_H
#include <QtGui>
#include <QtCore>
#include "paper.h"
class PaperManager : public QMainWindow
PaperManager();
QWidget *widget;
QPushButton *button0, *button1;
QGridLayout *layout;
int n;
int i;
QList<Paper> papers;
void readDirectory();
#endifCode: Alles auswählen
#include "papermanager.h"
#include <QtGui>
#include <QtCore>
// Daten einlesen
readDirectory();
// Menü
QMenu *fileMenu = new QMenu(tr("&File"), this);
menuBar()->addMenu(fileMenu);
fileMenu->addAction(tr("E&xit"), qApp, SLOT(quit()));
// Zentrum
button0 = new QPushButton("next...");
button1 = new QPushButton("previous...");
widget = new QWidget;
layout = new QGridLayout;
layout->addWidget(button0, 0, 0);
layout->addWidget(button1, 0, 1);
layout->addWidget(papers[0], 1, 0, 1, 2);
widget->setLayout(layout);
resize(640,480);
setCentralWidget(widget);
QDir dir("/media/data/paper");
dir.setFilter(QDir::Files);
QList<QFileInfo> files = dir.entryInfoList();
n = files.size();
for(i = 0; i < n; i++)
papers.append( new Paper(files[i]) );
}Code: Alles auswählen
#ifndef PAPER_H
#define PAPER_H
#include <QtGui>
#include <QtCore>
class Paper : public QWidget
Paper(QFileInfo fi);
QFileInfo fi;
#include "paper.h"
Paper::Paper(QFileInfo fi) : fi(fi)
QLabel *label = new QLabel(fi.absoluteFilePath());
QGridLayout *layout = new QGridLayout;
layout->addWidget(label);
setLayout(layout);
show();
}Beste Grüße,
der Luftballon
