Qtopia Kompilierproblem auf ARM
Sumpi
Beitrag von Sumpi »
Hallo!
Ich versuche derzeit Qtopia fr eine NetDCU8 cross zu kompilieren.
Ich verwende dazu folgendes configure command:
./configure --prefix=/usr/local/Trolltech/Qtopia-4.1.3_arm -embedded arm -depths 16 -little-endian -release -pch
Beim make bekomme ich dann folgenden Fehler (nach mehreren Minuten Kompilierzeit):
/opt/emlix/netdcu8/bin/arm-linux-gcc -c -include .obj/release-shared-emb-arm/QtCore -pipe -fno-exceptions -O2 -Wall -W -D_REENTRANT -fPIC -DQT_SHARED -DQT_BUILD_CORE_LIB -DQT_NO_CAST_TO_ASCII -DQT3_SUPPORT -DQT_MOC_COMPAT -DQT_NO_DEBUG -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE -I../../mkspecs/qws/linux-arm-g++ -I. -I../../include -I../../include/QtCore -Iglobal -I../3rdparty/zlib -I.moc/release-shared-emb-arm -I. -o .obj/release-shared-emb-arm/malloc.o arch/arm/malloc.c
arch/arm/malloc.c:5:2: invalid preprocessing directive #define
arch/arm/malloc.c:5525:1: unterminated #ifdef
arch/arm/malloc.c:5521:1: unterminated #ifdef
arch/arm/malloc.c:5328:1: unterminated #if
arch/arm/malloc.c:5324:1: unterminated #ifdef
arch/arm/malloc.c:5307:1: unterminated #if
arch/arm/malloc.c:5304:1: unterminated #ifdef
arch/arm/malloc.c:5292:1: unterminated #if
arch/arm/malloc.c:5288:1: unterminated #ifdef
arch/arm/malloc.c:5267:1: unterminated #if
arch/arm/malloc.c:5264:1: unterminated #ifdef
arch/arm/malloc.c:5253:1: unterminated #if
arch/arm/malloc.c:5221:1: unterminated #ifdef
arch/arm/malloc.c:5195:1: unterminated #ifdef
arch/arm/malloc.c:5167:1: unterminated #ifdef
arch/arm/malloc.c:5129:1: unterminated #ifdef
arch/arm/malloc.c:5085:1: unterminated #ifdef
arch/arm/malloc.c:5059:1: unterminated #ifdef
arch/arm/malloc.c:5005:1: unterminated #if
arch/arm/malloc.c:5002:1: unterminated #ifdef
arch/arm/malloc.c:4930:1: unterminated #ifdef
arch/arm/malloc.c:4915:1: unterminated #ifdef
arch/arm/malloc.c:4910:1: unterminated #ifdef
arch/arm/malloc.c:4908:1: unterminated #ifdef
arch/arm/malloc.c:4746:1: unterminated #if
arch/arm/malloc.c:4714:1: unterminated #if
arch/arm/malloc.c:4695:1: unterminated #ifdef
arch/arm/malloc.c:4673:1: unterminated #ifdef
arch/arm/malloc.c:4588:1: unterminated #if
arch/arm/malloc.c:4565:1: unterminated #if
arch/arm/malloc.c:4544:1: unterminated #if
arch/arm/malloc.c:4527:1: unterminated #if
arch/arm/malloc.c:4512:1: unterminated #if
arch/arm/malloc.c:4496:1: unterminated #if
arch/arm/malloc.c:4473:1: unterminated #ifdef
arch/arm/malloc.c:4371:1: unterminated #if
arch/arm/malloc.c:4350:1: unterminated #if
arch/arm/malloc.c:4333:1: unterminated #if
arch/arm/malloc.c:4283:1: unterminated #if
arch/arm/malloc.c:4177:1: unterminated #if
arch/arm/malloc.c:4115:1: unterminated #if
arch/arm/malloc.c:4113:1: unterminated #if
arch/arm/malloc.c:3981:1: unterminated #ifdef
arch/arm/malloc.c:3950:1: unterminated #if
arch/arm/malloc.c:3576:1: unterminated #if
arch/arm/malloc.c:3363:1: unterminated #if
arch/arm/malloc.c:3229:1: unterminated #if
arch/arm/malloc.c:3200:1: unterminated #if
arch/arm/malloc.c:3179:1: unterminated #if
arch/arm/malloc.c:3072:1: unterminated #if
arch/arm/malloc.c:3039:1: unterminated #if
arch/arm/malloc.c:2936:1: unterminated #if
arch/arm/malloc.c:2864:1: unterminated #if
arch/arm/malloc.c:2704:1: unterminated #if
arch/arm/malloc.c:2679:1: unterminated #if
arch/arm/malloc.c:2637:1: unterminated #if
arch/arm/malloc.c:2596:1: unterminated #if
arch/arm/malloc.c:2575:1: unterminated #if
arch/arm/malloc.c:2545:1: unterminated #if
arch/arm/malloc.c:2501:1: unterminated #if
arch/arm/malloc.c:2487:1: unterminated #if
arch/arm/malloc.c:2467:1: unterminated #if
arch/arm/malloc.c:1866:1: unterminated #if
arch/arm/malloc.c:1859:1: unterminated #if
arch/arm/malloc.c:1803:1: unterminated #if
arch/arm/malloc.c:1634:1: unterminated #if
arch/arm/malloc.c:1592:1: unterminated #ifdef
arch/arm/malloc.c:1560:1: unterminated #elif
arch/arm/malloc.c:1550:1: unterminated #if
arch/arm/malloc.c:1542:1: unterminated #ifdef
arch/arm/malloc.c:1540:1: unterminated #ifdef
arch/arm/malloc.c:1497:1: unterminated #if
arch/arm/malloc.c:1494:1: unterminated #ifdef
arch/arm/malloc.c:1478:1: unterminated #ifdef
arch/arm/malloc.c:1471:1: unterminated #if
arch/arm/malloc.c:1265:1: unterminated #if
arch/arm/malloc.c:1239:1: unterminated #if
arch/arm/malloc.c:1218:1: unterminated #if
arch/arm/malloc.c:1188:1: unterminated #if
arch/arm/malloc.c:1174:1: unterminated #if
arch/arm/malloc.c:1162:1: unterminated #if
arch/arm/malloc.c:1097:1: unterminated #if
arch/arm/malloc.c:1039:1: unterminated #if
arch/arm/malloc.c:1009:1: unterminated #if
arch/arm/malloc.c:980:1: unterminated #if
arch/arm/malloc.c:969:1: unterminated #if
arch/arm/malloc.c:951:1: unterminated #if
arch/arm/malloc.c:918:1: unterminated #if
arch/arm/malloc.c:907:1: unterminated #if
arch/arm/malloc.c:890:1: unterminated #if
arch/arm/malloc.c:845:1: unterminated #if
arch/arm/malloc.c:802:1: unterminated #ifdef
arch/arm/malloc.c:799:1: unterminated #ifdef
arch/arm/malloc.c:792:1: unterminated #ifdef
arch/arm/malloc.c:789:1: unterminated #ifdef
arch/arm/malloc.c:783:1: unterminated #ifdef
arch/arm/malloc.c:779:1: unterminated #if
arch/arm/malloc.c:776:1: unterminated #ifdef
arch/arm/malloc.c:770:1: unterminated #ifdef
arch/arm/malloc.c:742:1: unterminated #if
arch/arm/malloc.c:700:1: unterminated #if
arch/arm/malloc.c:630:1: unterminated #if
arch/arm/malloc.c:629:1: unterminated #if
arch/arm/malloc.c:628:1: unterminated #ifdef
arch/arm/malloc.c:614:1: unterminated #if
arch/arm/malloc.c:595:1: unterminated #if
arch/arm/malloc.c:592:1: unterminated #ifdef
arch/arm/malloc.c:590:1: unterminated #if
arch/arm/malloc.c:582:1: unterminated #ifdef
arch/arm/malloc.c:529:1: unterminated #ifdef
arch/arm/malloc.c:497:1: unterminated #ifdef
arch/arm/malloc.c:373:1: unterminated #ifdef
arch/arm/malloc.c:324:1: unterminated #ifdef
arch/arm/malloc.c:318:1: unterminated #if
arch/arm/malloc.c:311:1: unterminated #if
arch/arm/malloc.c:298:1: unterminated #if
arch/arm/malloc.c:275:1: unterminated #ifdef
arch/arm/malloc.c:246:1: unterminated #ifdef
arch/arm/malloc.c:10:1: unterminated #ifdef
arch/arm/malloc.c:8:1: unterminated #ifdef
arch/arm/malloc.c:1: internal compiler error: Segmentation fault
Bei QTopia 4.1.4 und 4.2 sehen die Fehlermeldungen zwar nicht gleich, aber hnlich aus.
Ich befrchte beinahe, dass es sich um einen Fehler beim BSP handelt,
bitte aber dennoch um jeglichen Ratschlag.
Schnen Gru,
Sumpi
Why geeks like computers:
unzip, strip, touch, finger, grep, mount, fsck,
more, yes,fsck,fsck,fsck,
umount, sleep
