GraphicsView Rechtecke verschieben
paule22
Beitrag von paule22 »
habe folgenden Code, der dazu dient, Rechtecke zu verschieben.
Allerdings haut da was nicht hin, wenn ich item1 verschiebe, dann
verschiebt sich item2 oder auch andersherum.
Woran kann das liegen?
Danke für Codesnippets und Sachdienliche Hinweise
#include <QtGui>
#include <QGraphicsItem>
#include <QGraphicsProxyWidget>
#include "designergraphicsview.h"
DesignerGraphicsView::DesignerGraphicsView(QWidget *parent) :
    QGraphicsView(parent)
    scene = new QGraphicsScene(this);
    this->setScene(scene);
    this->setGeometry(0,0,800,600);
    drag_item = nullptr;
    item1 = new DesignerItem;
    item2 = new DesignerItem;
    item1->setGeometry(4,4,100,100);
    item1->signal_mouse_press.connect(
                boost::bind(
                    &DesignerGraphicsView::OnMousePress,
                    this,_1)
    item2->setGeometry(54,54,100,100);
    item2->signal_mouse_press.connect(
                boost::bind(
                    this,_1)
    resizer = new QGraphicsRectItem;
    resizer->setRect(0,0, 106,106);
    resizer->setPen(QPen(Qt::red));
    resizer->setBrush(Qt::yellow);
    resizer->hide();
    scene->addItem(resizer);
    proxy1 = scene->addWidget(item1);
    proxy1->setPos(4,4);
    proxy1->setFlag(QGraphicsItem::ItemIsMovable,true);
    item_objects[item1] = proxy1;
    proxy2 = scene->addWidget(item2);
    proxy2->setPos(34,34);
    proxy2->setFlag(QGraphicsItem::ItemIsMovable,false);
    item_objects[item2] = proxy2;
void DesignerGraphicsView::OnMousePress(DesignerItem *item)
    assert(item);
    drag_item = item;
    resizer->show();
    if (drag_item == item1) {
    else if (item == item2) {
        proxy1->setFlag(QGraphicsItem::ItemIsMovable,false);
        proxy2->setFlag(QGraphicsItem::ItemIsMovable,true);
void DesignerGraphicsView::mouseMoveEvent(QMouseEvent *event)
    if (drag_item) {
        QPointF p = this->mapToScene(event->pos());
        item_objects[drag_item]->setPos(p-
        drag_item->m_pos);
        QPointF p2 = p;
        p2.setX(p2.x()-qreal(4.0));
        p2.setY(p2.y()-qreal(4.0));
        resizer->setPos(p2-drag_item->m_pos);
void DesignerGraphicsView::mouseReleaseEvent(QMouseEvent *event)
#ifndef DESIGNERGRAPHICSVIEW_H
#define DESIGNERGRAPHICSVIEW_H
#include <QWidget>
#include <QGraphicsView>
#include "designeritem.h"
class DesignerGraphicsView : public QGraphicsView
    explicit DesignerGraphicsView(QWidget *parent = 0);
signals:
public slots:
protected:
    void mouseMoveEvent(QMouseEvent *event);
    void mouseReleaseEvent(QMouseEvent *event);
    QGraphicsScene *scene;
    DesignerItem *drag_item;
    QGraphicsRectItem *resizer;
    QGraphicsProxyWidget *proxy1;
    QGraphicsProxyWidget *proxy2;
    DesignerItem *item1;
    DesignerItem *item2;
    std::map<DesignerItem*, QGraphicsProxyWidget*> item_objects;
    void OnMousePress(DesignerItem *item);
#endif // DESIGNERGRAPHICSVIEW_H
Re: GraphicsView Rechtecke verschieben
Was ist DesignerItem für ein Typ und wer implementiert signal_mouse_press() ? Warum überhaupt boost mit drin?
/edit: Ah sehe gerade dass dies Qt4 sein könnte - dann natürlich boost für das connect. Oder eben etwas anders schreiben damit es auch jeder versteht :)
Ich schätze dass das Signal OnMousePress() später kommt als mouseMoveEvent(). Kann man ja einfach mit Debugausgaben sehen.
paule22
Hallo Christian,
DesignerItem ist ein QWidget
Hope this Helps.
suche immer noch den Fehler.
#ifndef __DESIGNER_ITEM_H__
#define __DESIGNER_ITEM_H__
#include <QWidget>
#include <QtCore>
#include <QtGui>
#include <boost/signals2.hpp>
class DesignerItem : public QWidget
    explicit DesignerItem(QWidget *p = 0, Qt::WindowFlags f = 0);
    boost::signals2::signal<void (DesignerItem*)> signal_mouse_press;
    QPointF m_pos;
    QWidget *_p;
protected:
    void mousePressEvent(QMouseEvent * event);
    void paintEvent(QPaintEvent * event);
    QPainter p;
#endif
DesignerItem::DesignerItem(QWidget *p, Qt::WindowFlags f)
  : QWidget(p,f)
    _p = p;
void DesignerItem::mousePressEvent(QMouseEvent * event)
    m_pos = event->windowPos();
    signal_mouse_press(this);
    QWidget::mousePressEvent(event);
void DesignerItem::paintEvent(QPaintEvent *event)
    QRectF rectangle(0.0, 0.0, 97.0, 97.0);
    QBrush red(Qt::red);
    p.begin(this);
    p.drawRect(rectangle);
    p.end();
Wie gesagt - warum boost wenn es auch ohne geht und meine Vermutung hast du noch nicht verifiziert.
paule22
sodele, jetzt habe ich den boost kram rausgenommen,
und Qt5 Board-Eigene Mittel verwendet.
Aber das Problem besteht weiterhin.
#include <QWidget>
#include <QtCore>
#include <QtGui>
#include <QGraphicsRectItem>
    QPointF m_pos;
    QWidget *_p;
    class DesignerGraphicsView *view;
protected:
    QPainter p;
#endif
  : QWidget(p,f)
    _p = p;
    p.begin(this);
    p.end();
void DesignerItem::mousePressEvent(QMouseEvent *event)
    view->drag_item = this;
    qDebug() << this;
    view->resizer->show();
#include <QObject>
#include <QtGui>
#include <QVector>
QVector<QGraphicsProxyWidget *> proxies;
    item1 = new DesignerItem; item1->view = this;
    item2 = new DesignerItem; item2->view = this;
    resizer->hide();
    proxies << proxy1;
    proxies << proxy2;
    if (drag_item) {
        item_objects[drag_item]->setPos(p-drag_item->m_pos);
        QPointF p2 = p;
        p2.setX(p2.x()-4.0);
        p2.setY(p2.y()-4.0);
#include <QWidget>
signals:
public slots:
protected:
Mal geprüft ob ich recht habe?
Auch hier ein Hinweis: Zugriff auf Member-Variablen einer anderen Klasse sind nicht gerade guter Stil.
paule22
ja, wird mousePressEvent wird zuerst aufgerufen.
Dann sollte in drag_item auch das richtige Item stehen. Am besten beiden Items einen ObjectName geben und diesen per qDebug() im moveEvent ausgeben um wirklich sicher zu gehen.
paule22
ja, werden sie, mit jeweils unterschiedlichen Pointern.
Das Problem ist, dass, wenn ich beim 1. Mausklick und Move
die beiden items sich bewegen.
Es werden auch 2mal Mausclicks aktiviert.
Ich wüsste nicht warum. Kannst Du ein minimales, kompilierbares Beispiel als zip-Datei anhängen damit ich es mal komplett anschauen kann?
paule22
inzwischen habe ich es hinbekommen *freu :-)
Allerdings ist jetzt noch eines zu klären:
Wie bekommt man das item1, was sich hinter dem item2 befindet
in den Vordergrund?
Im Moment läuft es so, das es erstmal verschiebbar ist.
Und wie kann man dann den "resizer" rect mit nach vorne verschieben?
#include <QObject>
#include <QtGui>
#include <QVector>
                qreal(0.0  ), qreal(0.0),
                qreal(800.0), qreal(600.0),
                this);
    item1->setGeometry(0,0,100,100);
    item2->setGeometry(0,0,100,100);
    resizer->hide();
    proxy1->setPos(104,104);
    proxies << proxy1;
    proxy2->setPos(134,134);
    proxies << proxy2;
    if (item_objects[drag_item]) {
        qDebug() << "moveMaus";
        qDebug() << p;
        QPointF p2 = p;
#include <QWidget>
protected:
  : QWidget(p,f)
    _p = p;
        QRect rectangle(0,0, 97,97);
        p.begin(this);
        p.end();
    qDebug() << "MausPress:" << this;
    m_pos = event->localPos();
#include <QWidget>
#include <QtCore>
#include <QtGui>
    QPointF m_pos;
    QWidget *_p;
protected:
    QPainter p;
#endif
Jedes QGraphicsItem hat eine Z-Value -> setZValue()/zValue()
