QSqlRelationalTableModel/QDataWidgetMapper and empty fields
cotecmania
Beitrag von cotecmania »
Hello together,
I have a working model and mapper and the values are shown in several widgets.
If i set a filter to my modell which leads to zero data in the model, my widgets are not cleared. They keep their values from before setting the filter.
The same occurs when i have empty fields in a record.
This problem occurs only on fields which are not strings like numbers or dates.
My DB is an Access.mdb and is connected via QODBC.
Once again :
Textfields are cleared if they are empty, the others keep their values from the record before !
How can i solve this ?
Thanks in Advance
