Signal-Problem
Bullklaus_XXX
Signal-Problem
Beitrag von Bullklaus_XXX »
Hello,
i have a problem with the signal-slot connection:
connect( dode1, SIGNAL(sig_Text(char*)), this, SLOT(setText(char*)));
The signal is defined:
class SVGLDodecahedron : public QObject
signals:
void sig_Text(char*);
The slot is defined:
class SVMainWindow : public QWidget
public slots:
void setText(char*);
If I do now a:
emit sig_Text("There it is!");
in the class SVGLDodecahedron, but there is no reaction. (I have tested the slot with a button signal in the class SVMainWindow. That worked.)
Is there anyone who can help me?
klogg
Beitrag von klogg »
My first idea:
Maybe your emit command isn't triggered?
Perhaps you can post some example code?
HENNING
