Was muß ich im einzelnen tun um in einer Liste von Benutzer definierten Datentypen, Methoden wie QList::contains( const T & value ) ,QList::count( const T & value ) etc. verwenden zu können ?
Ich habe eine eigene Klasse erstellt (Tmessage)
BaseServer.h
class Tmessage:public QByteArray
protected:
Tmessage();
~Tmessage();
bool valid;
QList<Terror_msg> errors;
virtual Tmessage_hdr get_message_hdr();
virtual bool set_message_hdr(Tmessage_hdr);
virtual bool change_message_hdr(Tmessage_hdr);
bool operator==(/*const */Tmessage );
bool operator==(Tmessage_hdr );
bool operator==(const Tmessage &) const;
bool operator==(/*const */Tmessage_hdr );
bool operator!=(/*const*/ Tmessage );
bool operator!=(Tmessage_hdr );
bool operator!=(const Tmessage & ) const;
bool operator!=(/*const */Tmessage_hdr );
Q_DECLARE_METATYPE(Tmessage);
BaseServer.cpp
- Tmessage methods -
Tmessage::Tmessage()
valid = true;
Tmessage::~Tmessage()
Tmessage_hdr Tmessage::get_message_hdr()
if(this->size()<sizeof(Tmessage_hdr))
//critical error
Tmessage_hdr message_hdr;
QVariant converter(this->left(sizeof(Tmessage_hdr)));
if (converter.canConvert<Tmessage_hdr>())
message_hdr = converter.value<Tmessage_hdr>();
//critical error
return message_hdr;
bool Tmessage::set_message_hdr(Tmessage_hdr message_hdr)
QByteArray message_hdr_array;
QVariant converter;
converter.setValue(message_hdr);
if (converter.canConvert<QByteArray>())
message_hdr_array = converter.value<QByteArray>();
this->prepend(message_hdr_array);
return true;
return false;
bool Tmessage::change_message_hdr(Tmessage_hdr message_hdr)
QVariant converter;
this->replace(0,sizeof(Tmessage_hdr),message_hdr_array);
return true;
return false;
bool Tmessage::operator==(/*const*/ Tmessage &other) //const
const Tmessage_hdr message_hdr = (const Tmessage_hdr) this->get_message_hdr();
//message_hdr = this->get_message_hdr();
const Tmessage_hdr other_message_hdr = (const Tmessage_hdr) other.get_message_hdr();
//other_message_hdr = other.get_message_hdr();
if(message_hdr.id_nr == other_message_hdr.id_nr)
return true;
return false;
bool Tmessage::operator!=(/*const*/ Tmessage &other) //const
if(message_hdr.id_nr != other_message_hdr.id_nr)
return true;
return false;
bool Tmessage::operator==( Tmessage_hdr other)
Tmessage_hdr message_hdr = this->get_message_hdr();
// Tmessage_hdr other_message_hdr = other.get_message_hdr();
if(message_hdr.id_nr == other.id_nr)
return true;
return false;
bool Tmessage::operator!=(Tmessage_hdr other)
if(message_hdr.id_nr != other.id_nr)
return true;
return false;
bool Tmessage::operator==(const Tmessage_hdr &other) const
const Tmessage_hdr message_hdr = this->get_message_hdr();
return true;
return false;
bool Tmessage::operator!=(const Tmessage_hdr &other) const
return true;
return false;
nicht überladen
Ich erhalte die Fehlermeldung:
src/BaseServer.h:183: error: ‘bool Tmessage::operator==(Tmessage_hdr)’ cannot be overloaded
src/BaseServer.h:181: error: with ‘bool Tmessage::operator==(Tmessage_hdr)’
src/BaseServer.h:188: error: ‘bool Tmessage::operator!=(Tmessage_hdr)’ cannot be overloaded
src/BaseServer.h:186: error: with ‘bool Tmessage::operator!=(Tmessage_hdr)’
Wenn ich die Methoden weglasse, oder es mit bool Tmessage::operator==(const Tmessage_hdr)const oder ähnlichem versuche erhalte ich an der Stelle, wo ich die Liste mit QList::contains(messages) verwende, folgende Fehlermeldung:
/*adds ammessage to the message list.
The function has to be converted for working without index list
as soon as Tmessages "==" oprators work */
void Tconnection_manager::add_message(Tmessage message)
const Tmessage_hdr message_hdr = message.get_message_hdr();
//message_hdr = message.get_message_hdr();
if(messages.contains(message_hdr))
//error: message is already existing
messages.append(message);
//index.append(message_hdr.id_nr);
src/BaseServer.cpp: In member function ‘virtual void Tconnection_manager::add_message(Tmessage)’:
src/BaseServer.cpp:1563: error: no matching function for call to ‘QList<Tmessage>::contains(const Tmessage_hdr&)’
/usr/include/QtCore/qlist.h:654: note: candidates are: QBool QList<T>::contains(const T&) const [with T = Tmessage]
* Functions *
void register_base_server_metatypes()
qRegisterMetaType<Tmessage_hdr>("Tmessage_hdr");
qRegisterMetaType<Tmessage>("Tmessage");
qRegisterMetaType<Tconnection_state_name>("Tconnection_state_name");
qRegisterMetaType<Treply>("Treply");
qRegisterMetaType<Treply>("Tcm_command");
qRegisterMetaType<Tconnect_address_para>("Tconnect_address_para");
qRegisterMetaType<Tconnect_string_para>("Tconnect_string_para");
qRegisterMetaType<Tconnection_info>("Tconnection_info");
qRegisterMetaType<Tmessage_hdr_con_para>("Tmessage_hdr_con_para");
qRegisterMetaType<QAbstractSocket::SocketState>("QAbstractSocket::SocketState");
qRegisterMetaType<QAbstractSocket::SocketError>("QAbstractSocket::SocketError");
