* Copyright (C) 2007 by Peter Gaede *
* develop@linux-peter.de *
* This program is free software; you can redistribute it and/or modify *
* it under the terms of the GNU General Public License as published by *
* the Free Software Foundation; either version 2 of the License, or *
* (at your option) any later version. *
* This program is distributed in the hope that it will be useful, *
* but WITHOUT ANY WARRANTY; without even the implied warranty of *
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the *
* GNU General Public License for more details. *
* You should have received a copy of the GNU General Public License *
* along with this program; if not, write to the *
* Free Software Foundation, Inc., *
* 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA. *
#ifndef SINGLEAPPLICATION_H
#define SINGLEAPPLICATION_H
#include <QApplication>
class SingleApplication : public QApplication
SingleApplication(const QString &lockFile, int &argc, char **argv);
~SingleApplication();
bool isRunning() const;
QString lockFile() const;
bool m_isRunning;
QString m_lockFile;
bool checkForRunningInstance();
#endif // SINGLEAPPLICATION_H
#include "singleapplication.h"
#include <QFile>
#include <QProcess>
#include <QWidget>
#include <QMessageBox>
#include <QDir>
#include <unistd.h>
SingleApplication::SingleApplication(const QString &lockFile, int &argc, char **argv)
: QApplication(argc, argv)
m_lockFile = QString("%1/%2").arg(QDir::tempPath()).arg(lockFile);
m_isRunning = checkForRunningInstance();
SingleApplication::~SingleApplication()
if (!m_isRunning)
QFile file(m_lockFile);
if (file.exists())
file.remove();
bool SingleApplication::checkForRunningInstance()
// Check if lock file exists
if (file.exists())
// Now we check if a previous instance are running
if (file.open(QIODevice::Text | QIODevice::ReadOnly))
QString pid = QString(file.readLine());
file.close();
if (!pid.isEmpty())
QProcess p;
p.start("ps", QStringList() << "--pid" << pid);
p.waitForFinished();
QString data = QString(p.readAllStandardOutput());
if (data.contains(pid))
return true;
QWidget w;
QMessageBox::critical(&w, tr("Lock file error"), QString(tr("Unable to open lock file for reading:\n%1")).arg(m_lockFile));
return true;
// We are the only one instance, now we write our pid to lock file
if (file.open(QIODevice::Text | QIODevice::WriteOnly))
file.resize(0);
file.write(QString::number(getpid()).toAscii());
file.close();
QWidget w;
QMessageBox::critical(&w, tr("Lock file error"), QString(tr("Unable open lock file for writing:\n%1")).arg(m_lockFile));
return true;
return false;
QString SingleApplication::lockFile() const
return m_lockFile;
bool SingleApplication::isRunning() const
return m_isRunning;
#include <QDialog>
SingleApplication app(".singleapptest_lock", argc, argv);
if (app.isRunning())
return 0;
QDialog d;
d.show();
app.connect(&app, SIGNAL(lastWindowClosed()), &app, SLOT(quit()));
return app.exec();
