configure -qt-sql-mysql Problem hierbei ist folgende Meldung:
In file included from C:/MingW/bin/../lib/gcc/mingw32/3.4.5/../../../../include/
security.h:39,
from C:\Qt/src/corelib/io/qfsfileengine_win.cpp:68:
C:/MingW/bin/../lib/gcc/mingw32/3.4.5/../../../../include/ntsecpkg.h:123: error:
`SECURITY_STRING' does not name a type
C:/MingW/bin/../lib/gcc/mingw32/3.4.5/../../../../include/ntsecpkg.h:124: error:
C:/MingW/bin/../lib/gcc/mingw32/3.4.5/../../../../include/ntsecpkg.h:125: error:
C:/MingW/bin/../lib/gcc/mingw32/3.4.5/../../../../include/ntsecpkg.h:212: error:
typedef `PLSA_OPEN_SAM_USER' is initialized (use __typeof__ instead)
`PSECURITY_STRING' was not declared in this scope
expected primary-expression before ',' token
C:/MingW/bin/../lib/gcc/mingw32/3.4.5/../../../../include/ntsecpkg.h:213: error:
expected primary-expression before '*' token
expected primary-expression before ')' token
C:/MingW/bin/../lib/gcc/mingw32/3.4.5/../../../../include/ntsecpkg.h:224: error:
typedef `PLSA_GET_AUTH_DATA_FOR_USER' is initialized (use __typeof__ instead)
C:/MingW/bin/../lib/gcc/mingw32/3.4.5/../../../../include/ntsecpkg.h:225: error:
mingw32-make: *** [qfsfileengine_win.o] Error 1
Building qmake failed, return code 2
Wäre für eine Lösung sehr dankbar.
