#error "MMX/SSE instruction set not enabled"
zwutz
Beitrag von zwutz »
hallo,
versuche seit Tagen, Qt4.4.0 bei mir zu kompilieren
Nachdem ich diverse Hürden hatte bin ich jetzt auf das nächste Problem gestoßen:
d:/MinGW/bin/../lib/gcc/mingw32/3.4.2/include/mmintrin.h:34:3: #error "MMX instruction set not enabled"
d:/MinGW/bin/../lib/gcc/mingw32/3.4.2/include/xmmintrin.h:34:3: #error "SSE instruction set not enabled"
Die Config sieht so aus:
Environment:
    INCLUDE=
      D:\MinGW\include
      D:\Qt\4.4.0\include
    LIB=
      D:\WIN_SDK\v6.0A\lib
      D:\MinGW\lib
      D:\Qt\4.4.0\lib
    PATH=
      d:\cygwin\usr\local\bin
      d:\cygwin\bin
      d:\cygwin\bin
      d:\cygwin\usr\X11R6\bin
      c:\Windows\Microsoft.NET\Framework\v3.5
      c:\Windows\Microsoft.NET\Framework\v2.0.50727
      d:\WIN_SDK\v6.0A\bin
      d:\MinGW\bin
      d:\imagemagick
      c:\Windows\SYSTEM32
      c:\Windows
      c:\Windows\SYSTEM32\WBEM
      c:\WINDOWS\SYSTEM32\WINDOWSPOWERSHELL\V1.0\
      d:\Qt\4.4.0\bin
      d:\MiKTeX 2.7\miktex\bin
      c:\Users\zwutz\AppData\Local\Start++\LNKs
      c:\Users\zwutz\AppData\Local\Start++\CMDs
You are licensed to use this software under the terms of the GNU GPL version 2 or 3.
See D:/Qt/4.4.0/LICENSE.GPL2
 or D:/Qt/4.4.0/LICENSE.GPL3
Configuration:
    dist-config
    large-config
    medium-config
    minimal-config
    small-config
    full-config
    build_all
    debug
Qt Configuration:
    release
    debug
    zlib
    png
    accessibility
    opengl
    ipv6
    xmlpatterns
    webkit
    svg
    minimal-config
    small-config
    medium-config
    large-config
    full-config
QMAKESPEC...................win32-g++ (env)
Architecture................windows
Maketool....................mingw32-make
Debug symbols...............yes
Accessibility support.......yes
STL support.................yes
Exception support...........yes
RTTI support................yes
MMX support.................no
3DNOW support...............no
SSE support.................no
SSE2 support................no
IWMMXT support..............no
OpenGL support..............yes
Direct3D support............no
OpenSSL support.............no
QtDBus support..............no
QtXmlPatterns support.......yes
Phonon support..............no
WebKit support..............yes
Qt3 compatibility...........no
Third Party Libraries:
    ZLIB support............qt
    GIF support.............plugin
    TIFF support............plugin
    JPEG support............plugin
    PNG support.............qt
    MNG support.............plugin
Styles:
    Windows.................yes
    Windows XP..............yes
    Windows Vista...........yes
    Plastique...............yes
    Cleanlooks..............yes
    Motif...................yes
    CDE.....................yes
    Windows CE..............no
    Windows Mobile..........no
Sql Drivers:
    ODBC....................no
    MySQL...................no
    OCI.....................no
    PostgreSQL..............no
    TDS.....................no
    DB2.....................no
    SQLite..................plugin (qt)
    SQLite2.................no
    InterBase...............no
Sources are in..............D:\Qt\4.4.0
Build is done in............D:\Qt\4.4.0
Install prefix..............D:\Qt\4.4.0
Headers installed to........D:/Qt/4.4.0/include
Libraries installed to......D:/Qt/4.4.0/lib
Plugins installed to........D:/Qt/4.4.0/plugins
Binaries installed to.......D:/Qt/4.4.0/bin
Docs installed to...........D:/Qt/4.4.0/doc
Data installed to...........D:/Qt/4.4.0
Translations installed to...D:/Qt/4.4.0/translations
Examples installed to.......D:/Qt/4.4.0/examples
Demos installed to..........D:/Qt/4.4.0/demos
mit dem msvc2008 hat Qt anstandslos kompiliert, nur mit g++ hab ich derartige Probleme (und zwar mit mehreren Versionen, also auch der aktuellen)
langsam gehen mir die Ideen aus, was ich versuchen könnte -.-
Falls noch Infos vonnöten, bitte bescheid sagen
Cygwin/msys raus aus PATH sonst gibt es ein Durcheinander mit dem gcc von C:\MinGW\Bin und d:\cygwin\bin.
zwutz
Beitrag von zwutz »
bei der Installation von cygwin war ich schon so schlau, dort den gcc nicht auszuwählen
Aber mal sehn, nachdem ich einige Pfadangaben geändert habe (Leerzeichen raus) kompiliert es derzeit recht fleißig... nur das sich in unregelmäßigen Abständen der gcc mit einem segfault verabschiedet
Leerzeichen sind auch nicht unbedingt der Freund von Qt (qmake). gcc 3.4.5 läuft bei mir eigentlich recht stabil - und ich lasse sehr viel kompilieren...
