QT debuggen.
bw1faeh0
QT debuggen.
Beitrag von bw1faeh0 »
ich möchte mein QT Projekt unter Windows debuggen. Dazu habe ich bereits gdb installiert und will nun die Debug-Variante von QT kompilieren.
Vorsichtshalber habe ich QT neun installiert. Jedoch bekomme ich beim Kompilieren der Debugvariante folgende Fehlermeldung:
g++ -enable-stdcall-fixup -Wl,-enable-auto-import -Wl,-enable-runtime-pseudo-reloc -mthreads -Wl -shared -Wl,--out-implib,c:\Qt\4.3.2\lib\libQtCored4.a -o
"..\..\lib\QtCored4.dll" object_script.QtCored.Debug -L"c:\Qt\4.3.2\lib" -L"c:\Program Files\Microsoft Visual Studio .NET 2003\SDK\v1.1\Lib\" -L"c:\Qt\4.3
.2\lib" -lkernel32 -luser32 -lshell32 -luuid -lole32 -ladvapi32 -lws2_32 tmp\obj\debug_shared\QtCored_resource_res.o
Creating library file: c:\Qt\4.3.2\lib\libQtCored4.a
./tmp\obj\debug_shared\qfsfileengine_win.o: In function `Z8readLinkRK7QString':
C:/Qt/4.3.2/src/corelib/io/qfsfileengine_win.cpp:1328: undefined reference to `CoCreateInstance@20'
C:/Qt/4.3.2/src/corelib/io/qfsfileengine_win.cpp:1328: undefined reference to `CoInitialize@4'
C:/Qt/4.3.2/src/corelib/io/qfsfileengine_win.cpp:1328: undefined reference to `IID_IPersistFile'
C:/Qt/4.3.2/src/corelib/io/qfsfileengine_win.cpp:1328: undefined reference to `CoUninitialize@0'
./tmp\obj\debug_shared\qfsfileengine_win.o: In function `ZN13QFSFileEngine4linkERK7QString':
C:/Qt/4.3.2/src/corelib/io/qfsfileengine_win.cpp:1422: undefined reference to `CoCreateInstance@20'
C:/Qt/4.3.2/src/corelib/io/qfsfileengine_win.cpp:1422: undefined reference to `CoInitialize@4'
C:/Qt/4.3.2/src/corelib/io/qfsfileengine_win.cpp:1422: undefined reference to `IID_IPersistFile'
C:/Qt/4.3.2/src/corelib/io/qfsfileengine_win.cpp:1422: undefined reference to `CoUninitialize@0'
./tmp\obj\debug_shared\quuid.o: In function `ZN5QUuid10createUuidEv':
C:/Qt/4.3.2/src/corelib/plugin/quuid.cpp:411: undefined reference to `CoCreateGuid@4'
./tmp\obj\debug_shared\qeventdispatcher_win.o: In function `ZN28QEventDispatcherWin32Private16doWsaAsyncSelectEi':
C:/Qt/4.3.2/src/corelib/kernel/qeventdispatcher_win.cpp:390: undefined reference to `WSAAsyncSelect@16'
mingw32-make[2]: *** [..\..\lib\QtCored4.dll] Error 1
mingw32-make[2]: Leaving directory `C:/Qt/4.3.2/src/corelib'
mingw32-make[1]: *** [debug] Error 2
mingw32-make[1]: Leaving directory `C:/Qt/4.3.2/src/corelib'
mingw32-make: *** [debug-C__Qt_4_3_2_src_corelib] Error 2
C:\Qt\4.3.2\src>
Hat da jemand eine Idee, wo ich dran drehen kann?
Grüße
Christian
CoCreateInstance ist in ole32.dll - diese wird aber, wie man sieht, mit gelinkt. Also hast Du ggf. eine zu alte win32api - Version.
bw1faeh0
Danke für den Hinweis.
Aber wie soll man auf sowas kommen? Zumal ich ja die aktuelle Version des MinGW installier habe *grübel*
Leider hat das keinen Erfolg gebracht. Ich habe den Inhalt der gepackten Datei, die du verlinkt hast, in die entsprechenden Ordner von MinGW kopiert.
Das ändert aber am Ende nichts an der Fehlermeldung. QT berichtete bei der Installation übrigens auch, dass ich nicht die passende WinApi Version hätte. Leider sagte es nicht, welche ich benötige und welche ich installiert habe.
Noch eine Idee??
bw1faeh0
Kann man die Debug-Version der QT-Libs nicht irgendwo herunter laden?
CaptnChaos
Beitrag von CaptnChaos »
Erm....... Nö!
oetzi
Beitrag von oetzi »
hatte ähnliche Probleme die Qt-Debug-Version zu erstellen.
Das Visual Studio für .NET und MinGW waren ebenfalls installiert.
Nachdem ich die Umgebungsvariablen INCLUDE und LIB in C:\Qt\4.3.2\bin\qtvars.bat auf
set INCLUDE="C:\Qt\4.3.2\mkspecs\win32-g++\"
set LIB=""
am Anfang der Batch-Datei geändert hatte, lief der „Build Debug Libraries“ problemlos durch.
Ich hoffe, das klappt jetzt auch bei Dir.
oetzi
bw1faeh0
Danke für den Tipp. Ich probiere es mal aus!
bw1faeh0
Nee, sorry, der Fehler bleibt der gleiche :(
