[gelöst] Massive Probleme mit Compilieren unter DEV
moechild
Beitrag von moechild »
Servus, vielleicht kann mir jemand helfen; jetzt wo meine Nerven blank sind. Endlich habe ich es geschafft wie man den DEV konfigurieren muss um Qt zu programmieren, also verlinken. Habe alles wie in der Anleitung im C++-Forum gemacht: http://www.c-plusplus.de/forum/viewtopi ... -is-0.html
Leider scheitert das Compilieren, und es wird keine .exe -Datei erstellt.
Hier ist das Compiler-Log:
Compiler: Default compiler
Führt make... aus
make.exe -f "Makefile.Release" all
Makefile.Release:133: warning: overriding commands for target `release\main.o'
Makefile.Release:130: warning: ignoring old commands for target `release\main.o'
Makefile.Release:139: warning: overriding commands for target `release\main.o'
Makefile.Release:133: warning: ignoring old commands for target `release\main.o'
Makefile.Release:145: warning: overriding commands for target `release\main.o'
Makefile.Release:139: warning: ignoring old commands for target `release\main.o'
Makefile.Release:148: warning: overriding commands for target `release\main.o'
Makefile.Release:145: warning: ignoring old commands for target `release\main.o'
Makefile.Release:151: warning: overriding commands for target `release\main.o'
Makefile.Release:148: warning: ignoring old commands for target `release\main.o'
Makefile.Release:154: warning: overriding commands for target `release\main.o'
Makefile.Release:151: warning: ignoring old commands for target `release\main.o'
g++ -c -O2 -O2 -frtti -fexceptions -Wall -DUNICODE -DQT_LARGEFILE_SUPPORT -DQT_DLL -DQT_NO_DEBUG -DQT_CORE_LIB -DQT_GUI_LIB -DQT_THREAD_SUPPORT -DQT_NEEDS_QMAIN -I"C:/Programme/Qt/4.0.1/include/QtGui" -I"C:/Programme/Qt/4.0.1/include/QtCore" -I"C:/Programme/Qt/4.0.1/include" -I"." -I"C:/Programme/Qt/4.0.1/include/ActiveQt" -I"release" -I"." -I"C:/Programme/Qt/4.0.1/mkspecs/win32-g++" -o release\main.o WinMenu\main.cpp
WinMenu\main.cpp: In function `int WinMain(HINSTANCE__*, HINSTANCE__*, CHAR*, int)':
WinMenu\main.cpp:21: error: cannot convert `char[16]' to `const WCHAR*' in assignment
WinMenu\main.cpp:53: error: cannot convert `char*' to `const WCHAR*' for argument `2' to `HWND__* CreateWindowExW(DWORD, const WCHAR*, const WCHAR*, DWORD, int, int, int, int, HWND__*, HMENU__*, HINSTANCE__*, void*)'
WinMenu\main.cpp: In function `LRESULT WindowProcedure(HWND__*, UINT, WPARAM, LPARAM)':
WinMenu\main.cpp:95: error: cannot convert `CHAR*' to `const WCHAR*' for argument `2' to `int MessageBoxW(HWND__*, const WCHAR*, const WCHAR*, UINT)'
WinMenu\main.cpp:100: error: cannot convert `CHAR*' to `const WCHAR*' for argument `2' to `BOOL WinHelpW(HWND__*, const WCHAR*, UINT, DWORD)'
WinMenu\main.cpp:105: error: cannot convert `CHAR*' to `const WCHAR*' for argument `2' to `BOOL WinHelpW(HWND__*, const WCHAR*, UINT, DWORD)'
WinMenu\main.cpp:110: error: cannot convert `CHAR*' to `const WCHAR*' for argument `2' to `BOOL WinHelpW(HWND__*, const WCHAR*, UINT, DWORD)'
WinMenu\main.cpp:118: error: cannot convert `const char*' to `const WCHAR*' for argument `2' to `int MessageBoxW(HWND__*, const WCHAR*, const WCHAR*, UINT)'
make.exe: *** [release\main.o] Error 1
Ausführung beendet
Softwareinfo:
-DEV-C++-4.9.9.2
-Qt 4.0.1 mit mingw
Wenn jemand mir helfen könnte, wäre ich ausgesprochen dankbar!!!
Zuletzt geändert von moechild am 24. August 2006 11:48, insgesamt 1-mal geändert.
Qt ist mit UNICODE-Unterstützung kompiliert, also ist char falsch, man muss WCHAR benutzen.
Was ich allerdings nicht kapiere, ist die Tatsache dass Du Windows-Funktionen benutzt obwohl Du mit Qt arbeitest. Warum brauchst Du WinMain und DlgProc/WindowProcedure überhaupt?
moechild
Hier ist der Quellcode, den ich benutzt habe. Das ist das Tutorial-Beispiel von Trolltech.
#include <Qapplication.h>
#include <Qpushbutton.h>
QApplication a( argc, argv );
QPushButton hello( "Hello world!", 0 );
hello.resize( 100, 30 );
a.setMainWidget( &hello );
hello.show();
return a.exec();
Obwohl der Quellcode absolut korrekt ist, zeigt mir der Compiler ständig Fehler.
Sorry, aber das glaube ich nicht, ist es wirklich die Datei WinMenu\main.cpp ? Schau Dir mal die Fehler an - das kann gar nicht passen... hat DEV evtl. eine eigene main.cpp angelegt die jetzt kompiliert wird?
moechild
Jetzt habe ich endlich herausgefunden was ich falsch gemacht habe. Die Reihenfolge war eigentlich klar. Jedoch habe ich die Projektdateien im Example-Ordner vom DEV-Cpp eingefügt. Wenn man jetzt versucht mittels Konsole >qmake -project die .pro-Datei zu erzeugen werden anscheinend auch die ganzen anderen Beispiele von DEV-Cpp mit berücksichtigt.
Man muss das ganze Projekt in einem einzelnen Ordner stecken, sonst funktionierts nicht.
Und danke christian81 für den Rat, sonst hätte ich das nicht gemerkt.
Freudentränen
