ich habe eine Frage zum Patchen von QT. Nach der Installation von VS2005 Express und des Platform SDK habe ich den Patch in die Sourcen einbauen lassen und möchte nun "qconfigure.bat msvc2005" aufrufen. Bei mir sieht die Ausgabe zu Beginn dann folgendermaßen aus:
C:\Programme\Qt\4.1.0>qconfigure.bat msvc2005
This is the Qt/Windows Open Source Edition.
You are licensed to use this software under the terms of
the GNU General Public License.
Type '?' to view the GNU General Public License.
Type 'y' to accept this license offer.
Type 'n' to decline this license offer.
Do you accept the terms of the license?
y
Environment:
INCLUDE=
C:\Programme\Microsoft Platform SDK\Include
C:\Programme\Microsoft Visual Studio 8\VC\INCLUDE
C:\Programme\Microsoft Platform SDK\Include\.
LIB=
C:\Programme\Microsoft Platform SDK\Lib
C:\Programme\Microsoft Visual Studio 8\VC\LIB
C:\Programme\Microsoft Visual Studio 8\SDK\v2.0\lib
C:\Programme\Microsoft Platform SDK\Lib\.
PATH=
C:\Programme\Microsoft Visual Studio 8\Common7\IDE
C:\Programme\Microsoft Visual Studio 8\VC\BIN
C:\Programme\Microsoft Visual Studio 8\Common7\Tools
C:\Programme\Microsoft Visual Studio 8\SDK\v2.0\bin
C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727
C:\Programme\Microsoft Visual Studio 8\VC\VCPackages
C:\WINDOWS\system32
C:\WINDOWS
C:\WINDOWS\System32\Wbem
C:\Dokumente und Einstellungen\mb.ERNIE\Eigene Dateien
C:\PROGRA~1\Borland\Delphi6\Bin
C:\PROGRA~1\Borland\Delphi6\Projects\Bpl
C:\PROGRA~1\ATT\Graphviz\bin
C:\PROGRA~1\ATT\Graphviz\bin\tools
C:\Programme\cygwin\bin
C:\Programme\Microsoft Platform SDK\Bin\.
C:\Programme\Microsoft Platform SDK\Bin\WinNT\.
You are licensed to use this software under the terms of the GNU GPL.
See C:\Programme\Qt\4.1.0\LICENSE.GPL
Configuration:
minimal-config
small-config
medium-config
large-config
full-config
build_all
debug
Qt Configuration:
release
debug
zlib
no-gif
png
mng
accessibility
qt3support
opengl
ipv6
QMAKESPEC...................win32-g++ (env)
Architecture................windows
Maketool....................mingw32-make
Debug symbols...............yes
Accessibility support.......yes
STL support.................yes
Exception support...........yes
RTTI support................yes
OpenGL support..............yes
Third Party Libraries:
ZLIB support............qt
GIF support.............no
JPEG support............plugin
PNG support.............qt
MNG support.............qt
Styles:
Windows.................yes
Windows XP..............yes
Plastique...............yes
Motif...................yes
CDE.....................yes
Sql Drivers:
ODBC....................no
MySQL...................no
OCI.....................no
PostgreSQL..............no
TDS.....................no
DB2.....................no
SQLite..................no
SQLite2.................no
InterBase...............no
Sources are in..............C:\Programme\Qt\4.1.0
Build is done in............C:\Programme\Qt\4.1.0
Install prefix..............C:\Programme\Qt\4.1.0
Headers installed to........C:\Programme\Qt\4.1.0\include
Libraries installed to......C:\Programme\Qt\4.1.0\lib
Plugins installed to........C:\Programme\Qt\4.1.0\plugins
Binaries installed to.......C:\Programme\Qt\4.1.0\bin
Docs installed to...........C:\Programme\Qt\4.1.0\doc
Data installed to...........C:\Programme\Qt\4.1.0
Translations installed to...C:\Programme\Qt\4.1.0\translations
Examples installed to.......C:\Programme\Qt\4.1.0\examples
Demos installed to..........C:\Programme\Qt\4.1.0\demos
Processing of project files have been disabled.
Only use this option if you really know what you're doing.
Microsoft (R) Program Maintenance Utility, Version 8.00.50727.42
Copyright (C) Microsoft Corporation. Alle Rechte vorbehalten.
cl -c -Yc -Fptmp\qmake_pch.pch -Fotmp\qmake_pch.obj -nologo -Zm200 -GS -
wd4996 -O2 -MD -GR -EHsc -W3 -DUNICODE -DQT_LARGEFILE_SUPPORT -DQT_EDITION=QT_ED
ITION_DESKTOP -DQT_BUILD_QMAKE -DQT_BOOTSTRAPPED -DQT_NO_TEXTCODEC -DQT_NO_LIBRACode: Alles auswählen
Maketool....................mingw32-make Zum Datenbaksupport:
Sql Drivers:
InterBase...............no Macht es Sinn noch irgendwelche weitere Schalter zu nutzen? Was macht dieser "-fast" Schalter genau? Muss ich die einzelnen Subprojekte dann separat übersetzen (Designer/Assistent/...)
