QList<T>
This is by far the most commonly used container class. It stores a list of values of a given type (T) that can be accessed by index. Internally, the QList is implemented using an array, ensuring that index-based access is very fast.
Items can be added at either end of the list using QList::append() and QList::prepend(), or they can be inserted in the middle using QList::insert(). More than any other container class, QList is highly optimized to expand to as little code as possible in the executable. QStringList inherits from QList<QString>.
QLinkedList<T>
This is similar to QList, except that it uses iterators rather than integer indexes to access items. It also provides better performance than QList when inserting in the middle of a huge list, and it has nicer iterator semantics.
terators pointing to an item in a QLinkedList remain valid as long as the item exists, whereas iterators to a QList can become invalid after any insertion or removal.)
QVector<T>
This stores an array of values of a given type at adjacent positions in memory. Inserting at the front or in the middle of a vector can be quite slow, because it can lead to large numbers of items having to be moved by one position in memory.
QStack<T>
This is a convenience subclass of QVector that provides "last in, first out" (LIFO) semantics. It adds the following functions to those already present in QVector: push(), pop(), and top().
QQueue<T>
This is a convenience subclass of QList that provides "first in, first out" (FIFO) semantics. It adds the following functions to those already present in QList: enqueue(), dequeue(), and head().
QSet<T>
This provides a single-valued mathematical set with fast lookups.
QMap<Key, T>
This provides a dictionary (associative array) that maps keys of type Key to values of type T. Normally each key is associated with a single value. QMap stores its data in Key order; if order doesn't matter QHash is a faster alternative.
QMultiMap<Key, T>
This is a convenience subclass of QMap that provides a nice interface for multi-valued maps, i.e. maps where one key can be associated with multiple values.
QHash<Key, T>
This has almost the same API as QMap, but provides significantly faster lookups. QHash stores its data in an arbitrary order.
QMultiHash<Key, T>
This is a convenience subclass of QHash that provides a nice interface for multi-valued hashes.
