xml version einfügen
nkc
Beitrag von nkc »
ich habe eine xml Datei geschrieben.
Nur, ich schaffe es nicht, die version in der 1.Zeile zu schreiben.
Leider finde ich auch in der Doku nichts weiterführendes.
QDomDocument doc;
    QString version = "<?xml version = '1.0' encoding = 'ISO-8859-1'?>";
    doc.appendChild(doc.createEntityReference(version));
RHBaum
Beitrag von RHBaum »
Das was du schreiben willst, ist Teil des DOMDocuments selber, also eigentlich Attribute von dem Dom Document.
Mit
The QDomProcessingInstruction class represents an XML processing instruction.
Processing instructions are used in XML to keep processor-specific information in the text of the document.
The XML declaration that appears at the top of an XML document, typically <?xml version='1.0' encoding='UTF-8'?>, is treated by QDom as a processing instruction. This is unfortunate, since the XML declaration is not a processing instruction; among other differences, it cannot be inserted into a document anywhere but on the first line.
Do not use this function to create an xml declaration, since although it has the same syntax as a processing instruction, it isn't, and might not be treated by QDom as such.
The content of the processing instruction is retrieved with data() and set with setData(). The processing instruction's target is retrieved with target().
For further information about the Document Object Model see Level 1 and Level 2 Core. For a more general introduction of the DOM implementation see the QDomDocument documentation.
QDomProcessingInstruction QDomDocument::createProcessingInstruction ( const QString & target, const QString & data )
Creates a new processing instruction that can be inserted into the document, e.g. using QDomNode::appendChild(). This function sets the target for the processing instruction to target and the data to data.
If target is not a valid XML name, or data if contains characters which cannot appear in a processing instruction, the behavior of this function is governed by QDomImplementation::InvalidDataPolicy.
sollte weitere Informationen liefern !
