includepath openssl kann nicht gefunden werden
defenderLQ
Beitrag von defenderLQ »
Hi
ich versuche das es im project.pro datei unter Windows openssl include gefunden wird,
unter Linux gehts ohne probleme.
Habe schon verschiedenes probiert aber ohne erfolg,
wie es aussieht pthreads findet es aber openssl nicht.
win32 {
OBJECTS_DIR = temp/obj
MOC_DIR = temp/moc
DEFINES = WINDOWS_SYS WIN32
DESTDIR = lib
INCLUDEPATH += d:\Development\openssl-0.9.7g-xpgp-0.1c\include
UPNPC_DIR = ../../../../miniupnpc-1.0
PTHREADS_DIR = ../../../../pthreads-w32-2-8-0-release
ZLIB_DIR = ../../../../zlib-1.2.3
INCLUDEPATH += . $${PTHREADS_DIR} $${ZLIB_DIR} $${ZLIB_DIR}
win32 {
MOC_DIR = temp/moc
DESTDIR = lib
SSL_DIR = ../../../../openssl-0.9.7g-xpgp-0.1c
INCLUDEPATH += . $${SSL_DIR} $${PTHREADS_DIR} $${ZLIB_DIR} $${ZLIB_DIR}
Nun wo mache ich den einen fehler? ich weis genau das der pfad stimmt.
g++ -c -g -frtti -fexceptions -mthreads -Wall -DWINDOWS_SYS -DWIN32 -DPQI_USE_XP
GP -DMINIUPNPC_VERSION=10 -DQT_GUI_LIB -DQT_CORE_LIB -DQT_THREAD_SUPPORT -I"d:\Q
t\4.4.3\include\QtCore" -I"d:\Qt\4.4.3\include\QtCore" -I"d:\Qt\4.4.3\include\Qt
Gui" -I"d:\Qt\4.4.3\include\QtGui" -I"d:\Qt\4.4.3\include" -I"..\..\..\..\openss
l-0.9.7g-xpgp-0.1c\include" -I"." -I"..\..\..\..\pthreads-w32-2-8-0-release" -I"
..\..\..\..\zlib-1.2.3" -I"..\..\..\..\zlib-1.2.3" -I"d:\Qt\4.4.3\include\Active
Qt" -I"temp\moc" -I"." -I"d:\Qt\4.4.3\mkspecs\default" -o temp\obj\xpgp_id.o pqi
\xpgp_id.cc
In file included from pqi\xpgp_id.cc:5:
./pqi/authxpgp.h:37:25: openssl/ssl.h: No such file or directory
./pqi/authxpgp.h:38:25: openssl/evp.h: No such file or directory
In file included from ./pqi/pqi_base.h:38,
from ./pqi/authxpgp.h:45,
./pqi/pqinetwork.h:53:1: warning: "_WIN32_WINNT" redefined
In file included from D:/MinGW/bin/../lib/gcc/mingw32/3.4.2/../../../../include/
windows.h:48,
from ../../../../pthreads-w32-2-8-0-release/pthread.h:198,
from ./util/rsthreads.h:30,
from ./pqi/authxpgp.h:43,
D:/MinGW/bin/../lib/gcc/mingw32/3.4.2/../../../../include/windef.h:20:1: warning
Erstens sind \ nicht erlaubt, zweitens da -I"..\..\..\..\openssl-0.9.7g-xpgp-0.1c\include" im Compileraufruf vorkommt passt der Pfad definitiv nicht.
defenderLQ
also der pfad hat gestimmt aber mein openssl war nicht richtig, ich hatte mal openssl sources mit cygwin schon mal compiliert gehabt warscheinlich hat ein patch die includes geändert.
deswegen nun findet es die includes.
win32 {
MOC_DIR = temp/moc
DESTDIR = lib
SSL_DIR = ../../../../openssl-0.9.7g-xpgp-0.1c/include
INCLUDEPATH += . $${SSL_DIR} $${UPNPC_DIR} $${PTHREADS_DIR} $${ZLIB_DIR}
nun findet der compiler sys/times.h nicht
ft\ftfileprovider.cc:1:23: sys/times.h: No such file or directory
habe ich bei DEFINES was vergessen?
defenderLQ
defenderLQ hat geschrieben:also der pfad hat gestimmt aber mein openssl war nicht richtig, ich hatte mal openssl sources mit cygwin schon mal compiliert gehabt warscheinlich hat ein patch die includes geändert.
win32 {
MOC_DIR = temp/moc
DESTDIR = lib
syntax error
./upnp/upnputil.h:35: error: syntax error beforedirectory
irgendwie stimmt da was mit MinGW nicht oder?
unter cygwin und linux taucht da kein syntax error auf.
