Qt mit Cygwin complilieren
surfman19
Beitrag von surfman19 »
Kann man qt mit cygwin compilieren? Warum will er hier mingw verwenden?
Mein Versuch:
$ ./configure -debug-and-release -stl -platform win32-g++
This is the Qt for Windows Open Source Edition.
You are licensed to use this software under the terms of
the GNU General Public License (GPL) version 2 or 3.
Type '2' to view the GNU General Public License version 2 (GPLv2).
Type '3' to view the GNU General Public License version 3 (GPLv3).
Type 'y' to accept this license offer.
Type 'n' to decline this license offer.
Do you accept the terms of the license?
y
Setting Direct3D to NO, since the proper Direct3D SDK was not detected.
Make sure you have the Direct3D SDK installed, and that you have run
the <path to SDK>\Utilities\Bin\dx_setenv.cmd script.
The D3D SDK library path *needs* to appear before the Platform SDK library
path in your LIB environment variable.
All the required DirectShow/Direct3D files couldn't be found.
Make sure you have either the platform SDK AND the DirectX SDK or the Windows SD
K installed.
If you have the DirectX SDK installed, please make sure that you have run the <p
ath to SDK>\SetEnv.Cmd script.
Environment:
INCLUDE=
Unset
LIB=
Unset
PATH=
C:\cygwin\usr\local\bin
C:\cygwin\bin
C:\cygwin\bin
C:\cygwin\usr\X11R6\bin
c:\Programme\MiKTeX 2.7\miktex\bin
c:\WinAVR-20071221\bin
c:\WinAVR-20071221\utils\bin
c:\WINDOWS\system32
c:\WINDOWS
c:\WINDOWS\System32\Wbem
c:\ediabas\bin
c:\Programme\doxygen\bin
"C
C:\cygwin\Programme\Graphviz2.16\Bin"
c:\MSSQL7\BINN
c:\Programme\Java\jre1.6.0_03\bin
c:\Programme\Microsoft SQL Server\90\Tools\binn\
c:\Qt\4.4.1\bin
c:\Qt\4.4.1\qmake
c:\Programme\TortoiseSVN\bin
C:\cygwin\bin
C:\cygwin\usr\i686-pc-cygwin\bin
c:\Programme\OpenVPN\bin
You are licensed to use this software under the terms of the GNU GPL version 2 o
r 3.
See D:/qt-win-opensource-src-4.4.3/qt-win-opensource-src-4.4.3/LICENSE.GPL2
or D:/qt-win-opensource-src-4.4.3/qt-win-opensource-src-4.4.3/LICENSE.GPL3
Configuration:
dist-config
large-config
medium-config
minimal-config
small-config
full-config
build_all
debug
Qt Configuration:
release
debug
zlib
png
accessibility
qt3support
opengl
ipv6
xmlpatterns
webkit
svg
minimal-config
small-config
medium-config
large-config
full-config
QMAKESPEC...................win32-g++ (commandline)
Architecture................windows
Maketool....................mingw32-make
Debug symbols...............yes
Accessibility support.......yes
STL support.................yes
Exception support...........yes
RTTI support................yes
MMX support.................no
3DNOW support...............no
SSE support.................no
SSE2 support................no
IWMMXT support..............no
OpenGL support..............yes
Direct3D support............no
OpenSSL support.............no
QtDBus support..............no
QtXmlPatterns support.......yes
Phonon support..............no
WebKit support..............yes
Qt3 compatibility...........yes
Third Party Libraries:
ZLIB support............qt
GIF support.............plugin
TIFF support............plugin
JPEG support............plugin
PNG support.............qt
MNG support.............plugin
Styles:
Windows.................yes
Windows XP..............yes
Windows Vista...........yes
Plastique...............yes
Cleanlooks..............yes
Motif...................yes
CDE.....................yes
Windows CE..............no
Windows Mobile..........no
Sql Drivers:
ODBC....................no
MySQL...................no
OCI.....................no
PostgreSQL..............no
TDS.....................no
DB2.....................no
SQLite..................plugin (qt)
SQLite2.................no
InterBase...............no
Sources are in..............D:\qt-win-opensource-src-4.4.3\qt-win-opensource-src
-4.4.3
Build is done in............D:\qt-win-opensource-src-4.4.3\qt-win-opensource-src
-4.4.3
Install prefix..............D:\qt-win-opensource-src-4.4.3\qt-win-opensource-src
-4.4.3
Headers installed to........D:/qt-win-opensource-src-4.4.3/qt-win-opensource-src
-4.4.3/include
Libraries installed to......D:/qt-win-opensource-src-4.4.3/qt-win-opensource-src
-4.4.3/lib
Plugins installed to........D:/qt-win-opensource-src-4.4.3/qt-win-opensource-src
-4.4.3/plugins
Binaries installed to.......D:/qt-win-opensource-src-4.4.3/qt-win-opensource-src
-4.4.3/bin
Docs installed to...........D:/qt-win-opensource-src-4.4.3/qt-win-opensource-src
-4.4.3/doc
Data installed to...........D:/qt-win-opensource-src-4.4.3/qt-win-opensource-src
-4.4.3
Translations installed to...D:/qt-win-opensource-src-4.4.3/qt-win-opensource-src
-4.4.3/translations
Examples installed to.......D:/qt-win-opensource-src-4.4.3/qt-win-opensource-src
-4.4.3/examples
Demos installed to..........D:/qt-win-opensource-src-4.4.3/qt-win-opensource-src
-4.4.3/demos
Creating qmake...
execute: File or path is not found (mingw32-make)
Cleaning qmake failed, return code -1
Lg
cygwin wird von Qt4 nicht mehr unterstützt.
