ich möchte gerne mit einem ganz simplen C-Programm eine TCP-Verbindung zu einem Server aufbauen (also C-Programm als Client) und als Server ein Qt-Programm verwenden. Der Client-Code ist:
#include <sys/types.h>
#include <sys/socket.h>
#include <netinet/in.h>
#include <netdb.h>
#include <stdio.h>
#include <stdlib.h>
#define PORT 4711
#define BUF_SIZE 1024
int main(int argc, char *argv[]) {
int sock, run;
char buf[BUF_SIZE];
struct sockaddr_in server;
struct hostent *hp;
struct in_addr ia;
if (argc != 2) {
fprintf(stderr,"usage: client <hostname>\n");
exit(2);
// create socket
sock = socket(AF_INET, SOCK_STREAM, 0);
if (sock < 0) {
perror("error opening stream socket!");
exit(1);
server.sin_family = AF_INET;
// get internet address of host specified by command line
hp = gethostbyname(argv[1]);
if (hp == NULL) {
fprintf(stderr, "%s unknown host.\n", argv[1]);
exit(2);
} else {
printf("%s is a known host! adress = %d.%d.%d.%d = \n", hp->h_name, hp->h_addr_list[0][0], hp->h_addr_list[0][1], hp->h_addr_list[0][2], hp->h_addr_list[0][3]); //, inet_ntoa(server.sin_addr));
// copies the internet address to server adress
bcopy(hp->h_addr, &server.sin_addr, hp->h_length);
// set port
server.sin_port = PORT;
// open connection
printf("Trying to connect...\n");
if(connect(sock, (struct sockaddr*)&server,sizeof(struct sockaddr_in)) < 0)
perror("connecting stream socket");
exit(1);
} else {
printf("connect OK\n");
printf("OK\n");
strcpy(buf, "HELLO\n");
write(sock, buf, strlen(buf));
// read input from stdin
while(run=read(0,buf,BUF_SIZE)) {
if(run<0) {
perror("error reading from stdin");
exit(1);
// write buffer to stream socket
if(write(sock,buf,run) < 0)
perror("writing on stream socket");
exit(1);
close(sock);
Für den Server habe ich mir mit dem Designer ein Fenster erstellt und folgenden Code erstellt:
gpsview_visualiseTCPDataDialog.h:
#ifndef CLASSVISUALISETCPDATADIALOG_H
#define CLASSVISUALISETCPDATADIALOG_H
#include <QTcpServer>
#include <QMessageBox>
#include "ui_visualiseTCPData.h"
class visualiseTCPDataDialog : public QDialog, public Ui_visualiseTCPDataDialog
visualiseTCPDataDialog(QWidget *parent = 0);
private slots:
void slot_pbStartServerPressed();
void slot_pbStopServerPressed();
void slot_NewConnection();
QTcpServer *tcpServer;
#endif
gpsview_visualiseTCPDataDialog.cpp:
#include "gpsview_visualiseTCPDataDialog.h"
visualiseTCPDataDialog::visualiseTCPDataDialog(QWidget *parent) : QDialog(parent)
setupUi(this);
connect( pbStartServer, SIGNAL(clicked()), this, SLOT(slot_pbStartServerPressed()) );
connect( pbStopServer, SIGNAL(clicked()), this, SLOT(slot_pbStopServerPressed()) );
void visualiseTCPDataDialog::slot_pbStartServerPressed() {
printf("Starting server...\n");
tcpServer = new QTcpServer(this);
if (!tcpServer->listen(QHostAddress::Any, 4711)) {
QMessageBox::critical(this, tr("TCP Server"), tr("Unable to start the server: %1.") .arg(tcpServer->errorString()));
close();
return;
} else {
QMessageBox::information(this, tr("TCP Server"), tr("The server is running on port %1.\n"
"Run the Fortune Client example now.")
.arg(tcpServer->serverPort()));
connect( tcpServer, SIGNAL(newConnection()), this, SLOT(slot_NewConnection()) );
lbPort->setText( QString( "%1" ).arg(tcpServer->serverPort()) );
if (tcpServer->isListening()) {
printf("Server is listening!\n");
} else {
printf("Server is not listening!\n");
if (tcpServer->hasPendingConnections() ) {
printf("Server has pending connections!\n");
} else {
printf("Server has no pending connections!\n");
connect(tcpServer, SIGNAL(newConnection()), this, SLOT(slot_NewConnection()));
void visualiseTCPDataDialog::slot_pbStopServerPressed() {
printf("Stopping server...\n");
} else {
tcpServer->close();
lbPort->setText( QString( "?" ) );
} else {
void visualiseTCPDataDialog::slot_NewConnection() {
printf("New connection!\n");
cc -o client client.c && client localhost
client.c: In function ‘main’:
client.c:42: warning: incompatible implicit declaration of built-in function ‘bcopy’
client.c:58: warning: incompatible implicit declaration of built-in function ‘strcpy’
client.c:59: warning: incompatible implicit declaration of built-in function ‘strlen’
localhost is a known host! adress = 127.0.0.1 =
connecting stream socket: Connection refused
Ein "telnet localhost 4711" funktioniert, d.h. slot_NewConnection() zeigt "New connection!"...
Ich weiß, daß beim Server noch einiges fehlt. Ich möchte aber zunächst einfach nur die Verbindung aufbauen können...
Kann mir da jemand helfen?! Vielen Dank im Voraus,
Markus
