[gelöst] und wieder XML problem :)
ChMaster
Beitrag von ChMaster »
moin zusammen,
habe da mal wieder ein problemchen :roll:
wenn ich hier ein Item auswähle, liest er die endsprechende datei, funktioniert auch aber,
QString log, dart, exc, pryd, car, orc, ava, broc, lyo, sto, ys, cam;
log.append("keep-xml/de/logres/keeps.xml");
dart.append("keep-xml/de/dartmoor/keeps.xml");
exc.append("keep-xml/en/excalibur/keeps.xml");
pryd.append("keep-xml/en/prydwen/keeps.xml");
car.append("keep-xml/fr/carnac/keeps.xml");
orc.append("keep-xml/fr/orcanie/keeps.xml");
ava.append("keep-xml/full/avalon/keeps.xml");
broc.append("keep-xml/full/broceliande/keeps.xml");
lyo.append("keep-xml/full/lyonesse/keeps.xml");
sto.append("keep-xml/full/stonehenge/keeps.xml");
ys.append("keep-xml/full/ys/keeps.xml");
cam.append("keep-xml/pvp/keeps.xml");
QListViewItemIterator it( listView_Server );
	while( it.current() ){
		if ( listView_Server->currentItem()->text(0) == de_logres ){
			slotListViewFill( log );
		}else if ( listView_Server->currentItem()->text(0) == de_dartmoor ){
			slotListViewFill( dart );
		}else if ( listView_Server->currentItem()->text(0) == en_excalibur ){
			slotListViewFill( exc );
		}else if ( listView_Server->currentItem()->text(0) == en_prydwen ){
			slotListViewFill( pryd );
		}else if ( listView_Server->currentItem()->text(0) == fr_carnac ){
			slotListViewFill( car );
		}else if ( listView_Server->currentItem()->text(0) == fr_orcanie ){
			slotListViewFill( orc );
		}else if ( listView_Server->currentItem()->text(0) == full_avalon ){
			slotListViewFill( ava );
		}else if ( listView_Server->currentItem()->text(0) == full_broceliande ){
			slotListViewFill( broc );
		}else if ( listView_Server->currentItem()->text(0) == full_lyonesse ){
			slotListViewFill( lyo );
		}else if ( listView_Server->currentItem()->text(0) == full_stonehenge ){
			slotListViewFill( sto );
		}else if ( listView_Server->currentItem()->text(0) == full_ys ){
			slotListViewFill( ys );
		}else if ( listView_Server->currentItem()->text(0) == pvp_camlann ){
			slotListViewFill( cam );
		}else{
			++it;
hier mag er anscheinend mich nicht, warum? ist doch soweit alles in ordnung oder doch nicht? (genau hier hängt mein Programm , ich weiss
nicht warum :()
QListViewItem *item;
item = new QListViewItem( listView_KeepInfo );
item->setOpen( true );
QFile xmlKeep( fileName );
QDomDocument doc;
doc.setContent( &xmlKeep );
xmlKeep.close();
QDomNode node = doc.documentElement().firstChild();
while ( !node.isNull() ) {
         if ( node.toElement().tagName() == "keep" ){
            item->setText( 0, node.toElement().attribute( "id" ) );
            item->setText( 1, node.toElement().attribute( "guild" ) );
            item->setText( 2, node.toElement().attribute( "guildname" ) );
            item->setText( 3, node.toElement().attribute( "orig_realm" ) );
            item->setText( 4, node.toElement().attribute( "realm" ) );
            item->setText( 5, node.toElement().attribute( "relic" ) );
	 node = node.nextSibling();
Zuletzt geändert von ChMaster am 30. April 2005 01:24, insgesamt 1-mal geändert.
ChMaster
DBoxFE
DMS
First4 (Plugin-Develper)
Goos
Re: und wieder XML problem :)
Beitrag von Goos »
ChMaster hat geschrieben:hier mag er anscheinend mich nicht
Hehe, das ist ja mal ne schnuckelige Fehlermeldung. Dein Compiler hat dir wirklich gesagt, dass er dich nicht mag? :D :D :D
Vielleicht solltest doch etwas naeher darauf eingehen, was genau nicht funktioniert und welche Fehlermeldungen du bekommst.
Goos
ChMaster
ja so in etwa (ist mein gedanke-keine fehlermeldung)
mein programm hängt sich einfach auf, das öffnen der jeweiligen datei
funktioniert (mit QMessageBox getestet), also liegt es nicht am öffnen
der datei. sondern beim auslesen :(, ich weiss nicht woran das liegen
könnte??
ChMaster
DBoxFE
DMS
Goos
Beitrag von Goos »
Ok, was hast schon so alles probiert?
Deine item->setText() Zeilen mal rausgenommen?
Ueberprueft, ob dein XML-File auch passt?
Evtl. nen Zaehler ueber deine Nodes eingebaut und mal ausgegeben?
Goos
ChMaster
die datei stimmt (name) und die datei ist auch vorhanden.
item->setText() rausgenommen und hängt sich drotzdem auf??
zähler? ich versteh, aber wie :(
Zuletzt geändert von ChMaster am 29. April 2005 16:38, insgesamt 1-mal geändert.
ChMaster
DBoxFE
DMS
Goos
Beitrag von Goos »
Ok, dann mach hinne ;)
Goos
ChMaster
Goos hat geschrieben:Ok, dann mach hinne ;)
Goos
bin ja schon dabei sieh oben :)
habs net so mit zähl schleifen :roll:
habs so gemacht neues item in der schleife angelegt:
funktioniert drotzdem net ... (habe auch das item->setText() rusgenommen, siehe post oben)
    //item->setOpen( true );
    QDomDocument doc;
    xmlKeep.close();
        listView_KeepInfo->insertItem( item );
Zuletzt geändert von ChMaster am 29. April 2005 16:41, insgesamt 1-mal geändert.
ChMaster
DBoxFE
DMS
Goos
Beitrag von Goos »
Na einfach mal nen Zaehler in deine while Schleife einbauen und jeweils per Messagebox ausgeben lassen. Dann siehst wenigstens mal ob die Anzahl der Schleifendurchlaeufe mit der deiner Knoten im XML-File uebereinstimmt.
Goos
Goos
Beitrag von Goos »
ChMaster hat geschrieben: habs so gemacht neues item in der schleife angelegt:
Wenn das herausnehmen deiner item-> usw. Zeilen nix gebracht hat, dann aendert es sicher auch nichts, wenn du in der Schleife neue Items anlegst ;)
Goos
Goos
Beitrag von Goos »
Wieso bist du dir eigentlich so sicher, dass es genau an der von dir geposteten Stelle haengt?
Goos
ChMaster
Goos hat geschrieben:Wieso bist du dir eigentlich so sicher, dass es genau an der von dir geposteten Stelle haengt?
Goos
bin ich mir nicht, aber so wie ich es jetzt beim debugen erfahren habe
liest er sie immer wieder aus ??? wird wohl beim selectieren der items
in der listview sein ...
ChMaster
DBoxFE
DMS
ChMaster
es lag am selectiren der items ... nun funktioniert es :lol:
falsch:
      }else{
         ++it;
richtig: (glaube ich) :P
           }else{
                 //fehlermeldung ... ;)
ChMaster
DBoxFE
DMS
Goos
Beitrag von Goos »
*lach*....ja ich hab mal wieder aufs falsche Code-Stueck geschaut :)
In deiner ersten version kommst ja bei bekannten Eintraegen nie dazu, deinen Iterator weiterzuschieben. Folglich bist in ner seeehr lange andauernden Schleife :)
Goos
