ich versuche nen QTranslator zu nutzen, aber wenn ich mein Beispiel compiliere , dann fängt der Linker an zu meckern:
Mein TestProjekt besteht lediglich aus main.cpp und einem Widget mit ui.h (im Designer erstellt)# make
/usr/local/qt/bin/uic fenster.ui -o .ui/fenster.h
g++ -c -pipe -Wall -W -O2 -DQT_NO_DEBUG -DQT_SHARED -DQT_THREAD_SUPPORT -I/usr/local/qt/mkspecs/default -I. -I/usr/local/qt/include -I.ui/ -I. -I.moc/ -o .obj/main.o main.cpp
/usr/local/qt/bin/uic fenster.ui -i fenster.h -o .ui/fenster.cpp
g++ -c -pipe -Wall -W -O2 -DQT_NO_DEBUG -DQT_SHARED -DQT_THREAD_SUPPORT -I/usr/local/qt/mkspecs/default -I. -I/usr/local/qt/include -I.ui/ -I. -I.moc/ -o .obj/fenster.o .ui/fenster.cpp
/usr/local/qt/bin/moc .ui/fenster.h -o .moc/moc_fenster.cpp
g++ -c -pipe -Wall -W -O2 -DQT_NO_DEBUG -DQT_SHARED -DQT_THREAD_SUPPORT -I/usr/local/qt/mkspecs/default -I. -I/usr/local/qt/include -I.ui/ -I. -I.moc/ -o .obj/moc_fenster.o .moc/moc_fenster.cpp
g++ -Wl,-rpath,/usr/local/qt/lib -o language .obj/main.o .obj/fenster.o .obj/moc_fenster.o -L/usr/local/qt/lib -L/usr/X11R6/lib -lqt-mt -lXext -lX11-lm
.obj/fenster.o: In function `Fenster::init()':
fenster.cpp:(.text+0xfc): undefined reference to `myTrans'
fenster.cpp:(.text+0x1ae): undefined reference to `a'
fenster.cpp:(.text+0x1b3): undefined reference to `myTrans'
make: *** [language] Fehler 1
main.cpp:
#include <qapplication.h>
#include "fenster.h"
int main( int argc, char ** argv )
QApplication a( argc, argv );
QTranslator myTrans( 0 );
myTrans.load( QString( "language" ) +"DEU", "." );
a.installTranslator( &myTrans );
Fenster w;
w.show();
a.connect( &a, SIGNAL( lastWindowClosed() ), &a, SLOT( quit() ) );
return a.exec();
hier die fenster.ui.h:
** ui.h extension file, included from the uic-generated form implementation.
** If you wish to add, delete or rename functions or slots use
** Qt Designer which will update this file, preserving your code. Create an
** init() function in place of a constructor, and a destroy() function in
** place of a destructor.
#include <qtranslator.h>
extern QApplication a;
extern QTranslator myTrans;
void Fenster::init()
bool TransLoad;
textEdit->setText(tr( "falsches Passwort" ));
TransLoad=myTrans.load( QString( "language" ) +"ENU", "." );
if ( TransLoad==true )
textEdit->append("load of translator ok...");
textEdit->append(tr( "falsches Passwort" ));
textEdit->append("load of translator not ok...");
return;
Gruss,
needle
