static_cast funktioniert nicht mit Qt 5.3.0
Wowbagger
Beitrag von Wowbagger »
der folgende Code funktioniert einwandfrei mit Qt 5.2.1, jedoch nicht mit Qt 5.3.0. Kann mir jemand sagen, woran das liegt, bzw. einen Workaround vorschlagen. Der Code ist vereinfacht aus einem Fremdprojekt.
Danke!
    quint64 p = 1;
    const QFile::Permissions perm = static_cast< QFile::Permissions >( p );
Fehlermeldung:
g++ -c -pipe -g -Wall -W -D_REENTRANT -fPIE -DQT_CORE_LIB -I/opt/Qt/5.3/gcc_64/mkspecs/linux-g++ -I../test_static-cast -I/opt/Qt/5.3/gcc_64/include -I/opt/Qt/5.3/gcc_64/include/QtCore -I. -I. -o main.o ../test_static-cast/main.cpp
../test_static-cast/main.cpp: In function 'int main(int, char**)':
../test_static-cast/main.cpp:9:74: error: conversion from 'quint64 {aka long long unsigned int}' to 'QFlag' is ambiguous
../test_static-cast/main.cpp:8:13: note: candidates are:
     quint64 p = 1;
In file included from /opt/Qt/5.3/gcc_64/include/QtCore/qglobal.h:1065:0,
                 from /opt/Qt/5.3/gcc_64/include/QtCore/qcoreapplication.h:45,
                 from /opt/Qt/5.3/gcc_64/include/QtCore/QCoreApplication:1,
                 from ../test_static-cast/main.cpp:1:
/opt/Qt/5.3/gcc_64/include/QtCore/qflags.h:63:29: note: QFlag::QFlag(ushort)
     Q_DECL_CONSTEXPR inline QFlag(ushort ai) : i(int(uint(ai))) {}
/opt/Qt/5.3/gcc_64/include/QtCore/qflags.h:62:29: note: QFlag::QFlag(short int)
     Q_DECL_CONSTEXPR inline QFlag(short ai) : i(int(ai)) {}
/opt/Qt/5.3/gcc_64/include/QtCore/qflags.h:61:29: note: QFlag::QFlag(uint)
     Q_DECL_CONSTEXPR inline QFlag(uint ai) : i(int(ai)) {}
/opt/Qt/5.3/gcc_64/include/QtCore/qflags.h:60:29: note: QFlag::QFlag(int)
     Q_DECL_CONSTEXPR inline QFlag(int ai) : i(ai) {}
/opt/Qt/5.3/gcc_64/include/QtCore/qflags.h:108:29: note: initializing argument 1 of 'QFlags<T>::QFlags(QFlag) [with Enum = QFileDevice::Permission]'
     Q_DECL_CONSTEXPR inline QFlags(QFlag f) : i(f) {}
../test_static-cast/main.cpp:9:30: warning: unused variable 'perm' [-Wunused-variable]
Makefile:502: recipe for target 'main.o' failed
make: *** [main.o] Error 1
Re: static_cast funktioniert nicht mit Qt 5.3.0
Er kann sich einfach nicht entscheiden wie er das quint64 behandeln soll - entweder als ushort, short, uint oder int - wo ist das Problem?
Wowbagger
Christian81 hat geschrieben:Er kann sich einfach nicht entscheiden wie er das quint64 behandeln soll - entweder als ushort, short, uint oder int - wo ist das Problem?
Was verwendet er denn, wenn ich mit Qt 5.2.1 kompiliere?
Keine Ahnung - dort gibt es vielleicht nur einen ctor den er casten könnte - schau doch einfach nach welche ctors QFlags in Qt 5.2 hat.
