Kann mir vieleicht jemand helfen? Vielen Dank im Voraus.
Zustand PC
- Windows 10
- MinGw 6
- Umgebungsvaribalen in den Systemvariablen:
- C:\MinGw; C:\MinGw\bin; C:\MinGw; C:\MinGW\mingw32\bin; C:\Qt\qt486
- QMAKESPEC = win32-g++
Eingabe in der Konsole (Exemplareingabe, da dies das selbe Ergebnis auswirft wie meine eigentliche Konfiguration):
C:\Qt\qt486>configure -release -static -opensource -no-exceptions -platform win32-g++
This is the Qt for Windows Open Source Edition.
You are licensed to use this software under the terms of
the GNU Lesser General Public License (LGPL) version 2.1
or the GNU General Public License (GPL) version 3.
Type '3' to view the GNU General Public License version 3 (GPLv3).
Type 'L' to view the Lesser GNU General Public License version 2.1 (LGPLv2.1).
Type 'y' to accept this license offer.
Type 'n' to decline this license offer.
Do you accept the terms of the license?
y
All the required DirectShow/Direct3D files couldn't be found.
Make sure you have either the platform SDK AND the DirectShow SDK or the Windows SDK installed.
If you have the DirectShow SDK installed, please make sure that you have run the <path to SDK>\SetEnv.Cmd script.
vmr9.h not found
dshow.h not found
strmiids.lib not found
dmoguids.lib not found
msdmo.lib not found
d3d9.h not found
WARNING: Using static linking will disable the WebKit module.
Environment:
INCLUDE=
Unset
LIB=
Unset
PATH=
C:\Program Files (x86)\Common Files\Oracle\Java\javapath
C:\Program Files (x86)\Intel\iCLS Client\
C:\Program Files\Intel\iCLS Client\
C:\Windows\system32
C:\Windows
C:\Windows\System32\Wbem
C:\Windows\System32\WindowsPowerShell\v1.0\
C:\Windows\System32\OpenSSH\
C:\Program Files\Microsoft SQL Server\110\Tools\Binn\
C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common
C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL
C:\Program Files\Intel\Intel(R) Management Engine Components\DAL
C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT
C:\Program Files\Intel\Intel(R) Management Engine Components\IPT
C:\Program Files\TortoiseSVN\bin
C:\Program Files\Dell\Dell Data Protection\Drivers\TSS\bin\
C:\MinGW\
C:\MinGW\bin
C:\MinGW\mingw32
C:\Qt\qt486\bin
You are licensed to use this software under the terms of the GNU GPL version 3.You are licensed to use this software under the terms of the Lesser GNU LGPL version 2.1.
See C:/Qt/qt4863
or C:/Qt/qt486L
Configuration:
minimal-config
small-config
medium-config
large-config
full-config
release
Qt Configuration:
release
zlib
gif
tiff
jpeg
png
mng
accessibility
qt3support
opengl
s60
ipv6
script
scripttools
multimedia
audio-backend
declarative
native-gestures
largefile
svg
concurrent
minimal-config
small-config
medium-config
large-config
full-config
static
QMAKESPEC...................win32-g++ (commandline)
Architecture................windows
Maketool....................mingw32-make
Debug symbols...............no
Link Time Code Generation...no
Accessibility support.......yes
STL support.................yes
Exception support...........no
RTTI support................yes
MMX support.................yes
3DNOW support...............no
SSE support.................yes
SSE2 support................yes
IWMMXT support..............no
NEON support................no
OpenGL support..............yes
OpenVG support..............no
OpenSSL support.............no
QtDBus support..............no
QtXmlPatterns support.......no
Phonon support..............no
QtMultimedia support........yes
Large File support..........yes
NIS support.................no
Iconv support...............
Inotify support.............no
WebKit support..............no
Declarative support.........yes
Declarative debugging.......yes
QtScript support............yes
QtScriptTools support.......yes
Graphics System.............raster
Qt3 compatibility...........yes
DirectWrite support.........no
Use system proxies..........no
Third Party Libraries:
ZLIB support............qt
GIF support.............yes
TIFF support............yes
JPEG support............yes
PNG support.............yes
MNG support.............yes
FreeType support........no
Styles:
Windows.................yes
Windows XP..............no
Windows Vista...........no
Plastique...............yes
Cleanlooks..............yes
Motif...................yes
CDE.....................yes
Windows CE..............no
Windows Mobile..........no
S60.....................no
Sql Drivers:
ODBC....................no
MySQL...................no
OCI.....................no
PostgreSQL..............no
TDS.....................no
DB2.....................no
SQLite..................yes (qt)
SQLite2.................no
InterBase...............no
Sources are in..............C:\Qt\qt486
Build is done in............C:\Qt\qt486
Install prefix..............C:\Qt\qt486
Headers installed to........C:/Qt/qt486/include
Libraries installed to......C:/Qt/qt486/lib
Plugins installed to........C:/Qt/qt486/plugins
Imports installed to........C:/Qt/qt486/imports
Binaries installed to.......C:/Qt/qt486/bin
Docs installed to...........C:/Qt/qt486/doc
Data installed to...........C:/Qt/qt486
Translations installed to...C:/Qt/qt486/translations
Examples installed to.......C:/Qt/qt486/examples
Demos installed to..........C:/Qt/qt486/demos
WARNING: Using static linking will disable the use of plugins.
Make sure you compile ALL needed modules into the library.
Creating qmake...
g++ -c -oproject.o -O -I. -Igenerators -Igenerators/unix -Igenerators/win32 -Igenerators/mac -Igenerators/symbian -Igenerators/integrity -IC:\Qt\qt486/include -IC:\Qt\qt486/include/QtCore -IC:\Qt\qt486/include -IC:\Qt\qt486/include/QtCore -IC:\Qt\qt486/src/corelib/global -IC:\Qt\qt486/src/corelib/xml -IC:\Qt\qt486/mkspecs/win32-g++ -IC:\Qt\qt486/tools/shared -DQT_NO_TEXTCODEC -DQT_NO_UNICODETABLES -DQT_LITE_COMPONENT -DQT_NO_PCRE -DQT_NODLL -DQT_NO_STL -DQT_NO_COMPRESS -DUNICODE -DHAVE_QCONFIG_CPP -DQT_BUILD_QMAKE -DQT_NO_THREAD -DQT_NO_QOBJECT -DQT_NO_GEOM_VARIANT -DQT_NO_DATASTREAM -DQT_BOOTSTRAPPED -DQLIBRARYINFO_EPOCROOT -DQMAKE_OPENSOURCE_EDITION project.cpp
process_begin: CreateProcess(NULL, g++ -c -oproject.o -O -I. -Igenerators -Igenerators/unix -Igenerators/win32 -Igenerators/mac -Igenerators/symbian -Igenerators/integrity -IC:\Qt\qt486/include -IC:\Qt\qt486/include/QtCore -IC:\Qt\qt486/include -IC:\Qt\qt486/include/QtCore -IC:\Qt\qt486/src/corelib/global -IC:\Qt\qt486/src/corelib/xml -IC:\Qt\qt486/mkspecs/win32-g++ -IC:\Qt\qt486/tools/shared -DQT_NO_TEXTCODEC -DQT_NO_UNICODETABLES -DQT_LITE_COMPONENT -DQT_NO_PCRE -DQT_NODLL -DQT_NO_STL -DQT_NO_COMPRESS -DUNICODE -DHAVE_QCONFIG_CPP -DQT_BUILD_QMAKE -DQT_NO_THREAD -DQT_NO_QOBJECT -DQT_NO_GEOM_VARIANT -DQT_NO_DATASTREAM -DQT_BOOTSTRAPPED -DQLIBRARYINFO_EPOCROOT -DQMAKE_OPENSOURCE_EDITION project.cpp, ...) failed.
make (e=2): Das System kann die angegebene Datei nicht finden.
Makefile:329: recipe for target 'project.o' failed
mingw32-make: *** [project.o] Error 2
del project.o main.o makefile.o unixmake.o unixmake2.o mingw_make.o option.o winmakefile.o projectgenerator.o property.o meta.o makefiledeps.o metamakefile.o xmloutput.o pbuilder_pbx.o borland_bmake.o msvc_nmake.o msvc_vcproj.o msvc_vcxproj.o msvc_objectmodel.o msbuild_objectmodel.o symmake.o initprojectdeploy_symbian.o symmake_abld.o symmake_sbsv2.o symbiancommon.o registry.o epocroot.o gbuild.o qbitarray.o qbuffer.o qbytearray.o qcryptographichash.o qvsnprintf.o qbytearraymatcher.o qconfig.o qdatetime.o qdir.o qdiriterator.o qfile.o qtemporaryfile.o qfileinfo.o qabstractfileengine.o qfilesystementry.o qfilesystemengine.o qfilesystemengine_win.o qfilesystemiterator_win.o qfsfileengine.o qfsfileengine_iterator.o qfsfileengine_win.o qglobal.o qhash.o qiodevice.o qlibraryinfo.o qlist.o qlinkedlist.o qlocale.o qlocale_tools.o qlocale_win.o qmalloc.o qmap.o qregexp.o qtextcodec.o qutfcodec.o qstring.o qstringlist.o qsystemerror.o qsystemlibrary.o qtextstream.o quuid.o qvector.o qsettings.o qsettings_win.o qvariant.o qmetatype.o qxmlstream.o qxmlutils.o qnumeric.o
C:\Qt\qt486\qmake\project.o konnte nicht gefunden werden
Building qmake failed, return code 2
