kann mir jemand sagen, was hier schief geht??
typedef std::map<const QByteArray, TcpCommandFactory<TcpAbstractCommand>* > factoryActionMap;
typedef std::map<const QByteArray, factoryActionMap > factoryGroupMap;
factoryGroupMap _factoryMap;
const QByteArray groupName = factory->getGroupName();
pair<factoryGroupMap, bool> insertGroupState
= _factoryMap.insert( pair<const QByteArray, factoryActionMap>( groupName, factoryActionMap() ) );
Die insert- Methode schlägt immer fehlIn file included from c:\qt\qtcreator-2.3.0\mingw\bin\../lib/gcc/mingw32/4.4.0/include/c++/bits/stl_algobase.h:66,
from c:\qt\qtcreator-2.3.0\mingw\bin\../lib/gcc/mingw32/4.4.0/include/c++/bits/stl_tree.h:62,
from c:\qt\qtcreator-2.3.0\mingw\bin\../lib/gcc/mingw32/4.4.0/include/c++/map:60,
from ..\server\/TcpCommandFactories.h:6,
from ..\server\TcpCommandFactories.cpp:1:
c:\qt\qtcreator-2.3.0\mingw\bin\../lib/gcc/mingw32/4.4.0/include/c++/bits/stl_pair.h: In constructor 'std::pair<_T1, _T2>::pair(const std::pair<_U1, _U2>&) [with _U1 = std::_Rb_tree_iterator<std::pair<const QByteArray, std::map<const QByteArray, TcpCommandFactory<TcpAbstractCommand>*, std::less<const QByteArray>, std::allocator<std::pair<const QByteArray, TcpCommandFactory<TcpAbstractCommand>*> > > > >, _U2 = bool, _T1 = std::map<const QByteArray, std::map<const QByteArray, TcpCommandFactory<TcpAbstractCommand>*, std::less<const QByteArray>, std::allocator<std::pair<const QByteArray, TcpCommandFactory<TcpAbstractCommand>*> > >, std::less<const QByteArray>, std::allocator<std::pair<const QByteArray, std::map<const QByteArray, TcpCommandFactory<TcpAbstractCommand>*, std::less<const QByteArray>, std::allocator<std::pair<const QByteArray, TcpCommandFactory<TcpAbstractCommand>*> > > > > >, _T2 = bool]':
..\server\TcpCommandFactories.cpp:17: instantiated from here
c:\qt\qtcreator-2.3.0\mingw\bin\../lib/gcc/mingw32/4.4.0/include/c++/bits/stl_pair.h:101: error: no matching function for call to 'std::map<const QByteArray, std::map<const QByteArray, TcpCommandFactory<TcpAbstractCommand>*, std::less<const QByteArray>, std::allocator<std::pair<const QByteArray, TcpCommandFactory<TcpAbstractCommand>*> > >, std::less<const QByteArray>, std::allocator<std::pair<const QByteArray, std::map<const QByteArray, TcpCommandFactory<TcpAbstractCommand>*, std::less<const QByteArray>, std::allocator<std::pair<const QByteArray, TcpCommandFactory<TcpAbstractCommand>*> > > > > >::map(const std::_Rb_tree_iterator<std::pair<const QByteArray, std::map<const QByteArray, TcpCommandFactory<TcpAbstractCommand>*, std::less<const QByteArray>, std::allocator<std::pair<const QByteArray, TcpCommandFactory<TcpAbstractCommand>*> > > > >&)'
c:\qt\qtcreator-2.3.0\mingw\bin\../lib/gcc/mingw32/4.4.0/include/c++/bits/stl_map.h:170: note: candidates are: std::map<_Key, _Tp, _Compare, _Alloc>::map(const std::map<_Key, _Tp, _Compare, _Alloc>&) [with _Key = const QByteArray, _Tp = std::map<const QByteArray, TcpCommandFactory<TcpAbstractCommand>*, std::less<const QByteArray>, std::allocator<std::pair<const QByteArray, TcpCommandFactory<TcpAbstractCommand>*> > >, _Compare = std::less<const QByteArray>, _Alloc = std::allocator<std::pair<const QByteArray, std::map<const QByteArray, TcpCommandFactory<TcpAbstractCommand>*, std::less<const QByteArray>, std::allocator<std::pair<const QByteArray, TcpCommandFactory<TcpAbstractCommand>*> > > > >]
c:\qt\qtcreator-2.3.0\mingw\bin\../lib/gcc/mingw32/4.4.0/include/c++/bits/stl_map.h:159: note: std::map<_Key, _Tp, _Compare, _Alloc>::map(const _Compare&, const _Alloc&) [with _Key = const QByteArray, _Tp = std::map<const QByteArray, TcpCommandFactory<TcpAbstractCommand>*, std::less<const QByteArray>, std::allocator<std::pair<const QByteArray, TcpCommandFactory<TcpAbstractCommand>*> > >, _Compare = std::less<const QByteArray>, _Alloc = std::allocator<std::pair<const QByteArray, std::map<const QByteArray, TcpCommandFactory<TcpAbstractCommand>*, std::less<const QByteArray>, std::allocator<std::pair<const QByteArray, TcpCommandFactory<TcpAbstractCommand>*> > > > >]
c:\qt\qtcreator-2.3.0\mingw\bin\../lib/gcc/mingw32/4.4.0/include/c++/bits/stl_map.h:150: note: std::map<_Key, _Tp, _Compare, _Alloc>::map() [with _Key = const QByteArray, _Tp = std::map<const QByteArray, TcpCommandFactory<TcpAbstractCommand>*, std::less<const QByteArray>, std::allocator<std::pair<const QByteArray, TcpCommandFactory<TcpAbstractCommand>*> > >, _Compare = std::less<const QByteArray>, _Alloc = std::allocator<std::pair<const QByteArray, std::map<const QByteArray, TcpCommandFactory<TcpAbstractCommand>*, std::less<const QByteArray>, std::allocator<std::pair<const QByteArray, TcpCommandFactory<TcpAbstractCommand>*> > > > >]
mingw32-make[1]: *** [debug/TcpCommandFactories.o] Error 1
mingw32-make: *** [debug] Error 2
danke!
