Linkerprobleme mit static Qt 4.4.2/Mingw
Cartman
Beitrag von Cartman »
Ich habe nun auf zwei XP-Rechnern und einem Vista64-Rechner versucht, Qt 4.4.2 Open Source (d. h. mit Mingw) statisch zu bauen:
configure -static -release -platform win32-g++
Resultat (Stunden später beim Linken):
g++ -enable-stdcall-fixup -Wl,-enable-auto-import
-Wl,-enable-runtime-pseudo-rel
oc -Wl,-s -mthreads -Wl -Wl,-subsystem,windows -o
release\formExtractor.exe tmp/
obj/release_static/main.o tmp/obj/release_static/formextractor.o
tmp/obj/release
_static/mainwindow.o tmp/obj/release_static/moc_formextractor.o
tmp/obj/release_
static/moc_mainwindow.o tmp/obj/release_static/qrc_formextractor.o
-L"h:\tmp\qt
-4.4.2\lib" -L"h:\tmp\qt-4.4.2\lib" -lmingw32 -lqtmain -lQtWebKit
-lQtGui -lQtNe
twork -lgdi32 -lcomdlg32 -loleaut32 -limm32 -lwinmm -lwinspool -lmsimg32
-lQtCor
e -lkernel32 -luser32 -lshell32 -luuid -lole32 -ladvapi32 -lws2_32
tmp/obj/release_static/formextractor.o(.text+0xe0):formextractor.cpp:
undefined
reference to `_imp___ZN8QWebView6setUrlERK4QUrl'
tmp/obj/release_static/formextractor.o(.text+0x132):formextractor.cpp:
undefined
 reference to `_imp___ZNK8QWebView4pageEv'
tmp/obj/release_static/formextractor.o(.text+0x13d):formextractor.cpp:
undefined
 reference to `_imp___ZNK8QWebPage9mainFrameEv'
tmp/obj/release_static/formextractor.o(.text+0x310):formextractor.cpp:
undefined
tmp/obj/release_static/formextractor.o(.text+0x362):formextractor.cpp:
undefined
tmp/obj/release_static/formextractor.o(.text+0x36d):formextractor.cpp:
undefined
tmp/obj/release_static/formextractor.o(.text+0x718):formextractor.cpp:
undefined
tmp/obj/release_static/formextractor.o(.text+0x723):formextractor.cpp:
undefined
tmp/obj/release_static/formextractor.o(.text+0x73a):formextractor.cpp:
undefined
 reference to
`_imp___ZN9QWebFrame27addToJavaScriptWindowObjectERK7QStringP7QObj
ect'
tmp/obj/release_static/formextractor.o(.text$_ZN7Ui_Form7setupUiEP7QWidget[Ui_Fo
rm::setupUi(QWidget*)]+0x459):formextractor.cpp: undefined reference to
`_imp___
ZN8QWebViewC1EP7QWidget'
rm::setupUi(QWidget*)]+0x5b6):formextractor.cpp: undefined reference to
`_imp___
mingw32-make[4]: *** [release\formExtractor.exe] Error 1
mingw32-make[4]: Leaving directory
`H:/tmp/qt-4.4.2/examples/webkit/formExtracto
r'
mingw32-make[3]: *** [release] Error 2
mingw32-make[3]: Leaving directory
r'
mingw32-make[2]: *** [sub-formExtractor-make_default] Error 2
mingw32-make[2]: Leaving directory `H:/tmp/qt-4.4.2/examples/webkit'
mingw32-make[1]: *** [sub-webkit-make_default] Error 2
mingw32-make[1]: Leaving directory `H:/tmp/qt-4.4.2/examples'
mingw32-make: *** [sub-examples-make_default-ordered] Error 2
"Workaround" bisher:
configure ... -no-webkit
Dann geht's. Was läuft hier falsch? Warum kann ich nur ohne Webkit bauen?
patrik08
Beitrag von patrik08 »
Wann hast du Mingw das letzte mal updated?
Ich habe wie in http://wiki.qtcentre.org/index.php?titl ... dows#MinGW beschrieben ist qt4.5 static gebaut ohne problemen... mit WebKit ... jedoch keinen phonon.
extraiere MingW aus ftp://ftp.trolltech.com/qt/source/qt-wi ... -mingw.exe die ist super ... nur noch Minimal sys installieren und wget ub externe lib zu bauen...
Warum willst du static bauen?
IMO: mich wundert das es keine "emerge" gibt um qt zu bauen mit VS oder Mingw wie KDE win.
http://techbase.kde.org/Getting_Started ... ows/emerge
Python hat man doch fast immer im PC.
Cartman
Ich benutze das Mingw aus dem offiziellen Qt 4.4.1 Installer. Die Version ist:
gcc version 3.4.2 (mingw-special)
Zur Version 4.4.2 sollte sich der Compiler nicht geändert haben. Den exotischen Static-Build brauche ich für so eine MATLAB-Plugin-Sache. MATLAB liefert selbst (alte und wechselnde) Qt-Bibliotheken für seinen eigenen Komponenten mit. Mit dem Static-Build vermeide ich da Kollisionen.
wget? MSYS hab ich nicht installiert. wget 1.10.2 ist in meinem texlive-Pfad, wie ich gerade sehe.
webkit ging imho noch nie statisch in 4.4.x
Cartman
Christian81 hat geschrieben:webkit ging imho noch nie statisch in 4.4.x
Ahso, dachte nur, ich würde irgendwo was falsch machen. Ich kann ansonsten auch gut auf das Webkit verzichten. Danke.
patrik08
Cartman hat geschrieben:I
MSYS http://www.mingw.org/wiki/msys ist einfach ein riesigen freund & helfer und gibt eine richtige console das einfuegen von text geht ueber CTRL+L oder was in der richtung , brauche ich nicht da ich script file brauche sh .
IMO: nicht noetig fuer jenigen die keine externe lib brauchen
Wget ist einfach eine download help
#! /bin/sh -e
######## http://heanet.dl.sourceforge.net/sourceforge/mingw/wget-1.9.1-mingwPORT.tar.bz2
tar -xvjf wget-1.9.1-mingwPORT.tar.bz2
rm wget-1.9.1-mingwPORT.tar.bz2
mkdir /usr/src
mkdir /usr/local
mkdir /usr/local/bin
cd wget-1.9.1/mingwPORT
cp wget.exe /usr/local/bin
./mingwPORT.sh
cd
rm -rf wget-1.9.1
Nehmen wir an man soll 4 oder 5 externe lib holen und compilieren
libxml2 + libxslt + exiv2 um bilder camera info zu haben.
dan lade ich ein sh script wie dieses:
http://fop-miniscribus.googlecode.com/s ... ingwdep.sh
und innert wenigen minuten habe ich lib frisch gebaut...
Auf dieser weise kann man selber entscheiden
./configure --enable-static --disable-shared --prefix=$PWD/../../
Und somit werden viele lib statisch und nicht dll
